Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Locked memory card
I am trying to unlock my camera, and I'm not very sure how I am supposed to do this. I can't take any pictures anymore, and I will be leaving out of my state soon. Please help as soon as you can. Thanks
  • Canon Master
  • 2,794 Answers
Remove your memory card from your camera. on the left side of the memory card has an unlock switch. Just raise the switch to unlock it.
Posted on Jul 14, 2008
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Card locked
Couple of things could be the problem one is that the card is actually locked and I'll include a diagram so you know where it's suppose to be and the other is the card may need formatting. The memory card when new needs to be formatted to the camera it is to be used in and after each time pictures are downloaded to the computer. Formatting cleans the memory card and makes it ready for new pictures to be loaded at optimum speed.
Here is the lock position diagram. Lock is in the direction of the arrow unlock is up see small circle
Jan 04, 2011 | HP Photosmart E217 Digital Camera
I didn't get a memeory card with my new camera.
First, new cameras don't come with memory cards anymore. Make sure the slide switch on the side of the card is in the unlocked position. Then, format the card in the camera.
Dec 19, 2009 | Canon PowerShot A540 Digital Camera
Memory card problem
Hi and welcome to FixYa.
I'm not sure about your particular instance, but this can happen if you change up cameras or use a card reader.
As for being unable read the memory card, sometimes the card can be switched off by accident. Turn off the camera and remove the card. Look at the side of the card and there will be a little switch. One end says locked (or shows a little picture of a locked lock) and the other end says unlocked (or, shows a little picture of an unlocked lock). Just move the switch to unlocked.
Try that, and let me know with a comment if that doesn't work, othewise, thanks for coming to FixYa!
Rob
Mar 02, 2009 | Kodak EasyShare One Digital Camera
My memory card in my camera keeps saying its protected
Hi there, My name is Rob and I can help you. Do this:
Make sure the camera is off and pull out the SD card. Look on the side of the card. You will see a little switch. One side says locked (or shows a little picture of a locked lock) the other side says unlocked (or shows a little picture of an unlocked lock). Make sure the switch is in the unlocked position and reinsert it properly into the camera.
This will fix your problem. Thanks for coming to FixYa. Let me know if I can be of anymore help. Don't forget to rate my answer a fixya!
Rob
Feb 23, 2009 | Fuji FinePix S304 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
I recently bought the camera and was able to take 45 pictures without a memory card. I then put a memory card in from my phone and it allowed me to take pictures. However, once I took the card out and...
Be sure that the Lock switch on the memory card in your camera is set to unlock. If it is unlocked then try and see if you can reformat the card with the camera.
Jun 10, 2008 | Samsung Cameras
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
