Question about ASUS P4S800- MX 661FX SOCKET478 800FSB PRESCOTT 2DDR AUD+VDO+LAN 3PCI+AGP8X UATX (P4S800MXPRESCOTT) Motherboard
Help setting up motherboard
I'm trying to set up a motherboard,,manually connecting the wires,,could u help me i don't know wut to put where
    Sergeant:
  • 287 Answers
Www.asus.com
select global or your country
select downloads
type P4 into search and select you board from list
select manuals
download
Posted on Jul 14, 2008
I have G43 ECS mother board based computer. I do not have connection diagram for the front panel connections wires ( about 8 wires not connected by a single connector). The ECS FAQ does not help
You could see that proper connections in the owners manual. If you don't have the manual, just type the boards type in any browser and download the manual!
Hope that helps u out!
Jun 09, 2011 | ECS 945G-M3 (V3.0) Motherboard
I JUST NEED TO KNOW WHERE THE PUT THE CABELES DOWN AT TH BOTTOM. LIKE POWER RESET I WANT TO KNOW SEEN AND VERIFY ITS RIGHT
motherboard has user manual try to read it again, if you do not have manual then use a magnifying glass look for word abbreviated: Pwr- power switch, Re-re-set power, Hd- hard drive etc.. this is where you connect the wire, LED light etc.
Feb 12, 2011 | Abit Fatal1ty AN8 SLi Motherboard
Wires for USB go to which MoBo pins?
there is two sets of 4 pin on each with an xtra ground you may not use.
Here is the link for your motherboard manual which shows the connections.
i.e you can connect your two sets of 4 wires to usb 1 or split them i.e 1 set of 4 on usb 1 and 1 set of 4 on usb 2.
http://zhornyak.com/soyo/Soyo_P4X400_Manual.pdf
Oct 06, 2009 | Soyo P4X400 Dragon Lite (P4X400DRAGNLITE)...
Usb connection order PLZ HELP
You should have told me you are missing a manual. If you dont follow thing from it correctly, you can really burn your motherboard. from the usb connectors on the motherboard
you see pins like this 1 is set 1 and 2 is set 2. you see those are wrapped in sets from you cable near the end. dont mix them
ooooo 12345
oooo 6789
lets put it this way
vcc1 = 1
-d1 = 2
+d1 = 3
GND1 = 4
nothing on 5
vcc2 = 6
-d2 = 7
+d2 = 8
GND2 = 9
May 12, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Motherboard P4M800CE-8237 Pin connection
Hi ohfs55, case's vary & so do the wire colors. The most common wire color for positive are colored wires. Blue, Green, & red. The most common color for negative is White & or black. I wasn't able to find your manual. If you have the manual for the motherboard there will be a page that will show where the positive & negative wire's connect for each jumper to the motherboard.
Without the manual I can not guide you through each connection. PW = power switch, RW =Reset switch, HD_LED = Hard drive LED ECT.
Mike
Oct 21, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Wire connections/installation
the +/- wires don;t really mater ! but as a general rule, the writing on the cable connectors should be facing you !
i don;t realy understand what u don;t understand, it-s easy, u guide u're self from the diagram on the motherboard (the one u tried to draw) (in the first raw on the left u put the power led cable, under it the reset cable .....)
there is no problem if u get them wrong, u can't damage anyting, so u can try until u get them right
Jan 20, 2008 | Soyo SY-K7V Dragon Motherboard
I lost my manual on hooking up the wiring on my nforce3-a motherboard.
Chances are, you can download the manual from the website of the manufacturer. That's probably the smart move. Last thing you want to do is try and do connections without it. That's a quick way to go through more than one.
JD
Digital Advisor
Dec 01, 2007 | EliteGroup nForce3-A Motherboard
Power button wiring help
Hello Chub, Your motherboard manual can be downloaded at this link: http://support.asus.com/download/download.aspx?SLanguage=en-us If you go to page 2-31 in the above manual the diagram should show you exactly where your front panel power switch connects to your motherboard. You want to connect it to the position marked below as ?ATX Power Switch?. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 15, 2007 | ASUS A8V Deluxe Motherboard
ASUS P4S800- MX 661FX SOCKET478 800FSB PRESCOTT 2DDR AUD+VDO+LAN 3PCI+AGP8X UATX (P4S800MXPRESCOTT) Motherboard Logo
153 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
