Question about Zenith B32A24Z 32" TV
Zenith B32A24Z Digital Tuner?
Does the Zenith Television Model B32A24Z have a Digital Tuner?
  • Anonymous Mar 28, 2009
    does it have a digital tuner
I have an B36A24Z Zenith TV set Does this set have a digital
tuner?
Posted on Jan 18, 2009
Can I use my zenith TV tuner converter box model number dtt901 to watch my phone on TV
The Zenith DTT901 receives OTA (over-the-air) digital signals from TV stations and converts them to an analog signal to be used with an older analog television.
So the answer is no.
Nov 26, 2017 | Zenith Televison & Video
Where can I find the value of a Zenith TV B32A24Z
Contact the authorized service center for Zenith
Aug 31, 2012 | Zenith B32A24Z 32" TV
The cable connector has been broken off from the outside, is there any way of fixing this without replacing the entire board
Yes...if you can remove the board from the TV safely. You will have to unsolder the tuner. Then remove the sides of the tuner to inspect the damage. You will need to replace the RF connector with an RCA part #215543. On another note, find an old TV repair shop and see if they can salvage a tuner from an identical TV. This is actually faster and easier to repair. Note this, just replace the tuner, not the main board. The salvaged unit may not be serviceable. Thanks for asking and show all hands of support!
May 16, 2011 | Zenith B32A24Z 32" TV
The cable connector has been broken off. is there any way of fixing this without replacing the entire board
With most tv's I've serviced, the cable connector is connected directly to the tuner module. The tuner module may be damaged beyond repair, depending upon how much physical force was applied to the cable connector. I would take it to a reputable repair shop and let them provide you a honest estimate of repair. They may be able to resolder the cable connector to the tuner module.
Is the L20V36 zenith ready for the new tv changes
Having looked at the specs for this TV, it would indicate that to receive digital pictures, you would indeed need an external set-top-box, as the tuner in the TV is a standard NTSC tuner, not a DTV tuner.
Jul 20, 2010 | Zenith L20V36 20.1 in. EDTV-Ready LCD...
I have Zenith B32A24Z, when I rurn it on it cuts of, it also has sound. What is the problem.
the best way is to do isolation method, first start with a power supply, check some semi conductors and diodes
secondly check the line transformer section.
just this two tests will make your tv work
Apr 24, 2009 | Zenith B32A24Z 32" TV
Is this a digital tv? can i get a manual?
if the set is over 2 years old it more than likely wont be a digital set. press the AV button that should switch you between digital and analogue if the set has digital in it
Mar 08, 2009 | Zenith B32A24Z 32" TV
Zenith tv model #A32B41W
You probably need to get into the Menu > Tuner Setup and set it for "Cable" instead of "Off Air".
Hope that helps...
Geno
Mar 22, 2008 | Zenith B32A24Z 32" TV
Zenith B32A24Z 32" TV Logo
283 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
