Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP6210 Print Assembly
The fine wires that hold the print cartridge in broke. I do not know .. but I may need a new print carriage. Where do I get one? Or does anyone hve an other suggestions? .
Mike
  • HP Master
  • 2,794 Answers
That wire controls your print carriage. It probably would cost more to get it fixed than to get a new one. You might be able to find one that uses the same cartridges.
Posted on Jul 14, 2008
My HP Photoshop Premium Model C410a has stopped printing the black text. I am not getting any error message and have put new cartridge in but still nothing. Have done a print quality check and all looks...
check Printer's head Carriage assembly unit ( any Cartridge supporting mechanism are break ).
change print Head Carriage assembly unit.
Oct 27, 2013 | HP PhotoSmart Office Equipment & Supplies
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
My Deskjet 9800 has both cartridge lights flashing. I've put in new cartridges and ensured that they are properly seated. I cannot print a test page.
you will need to replace the carriage assembly because the cartridge has punched a small hole in the circuit contact board, which broke the circuit
Feb 06, 2010 | HP DeskJet 9800 InkJet Printer
How do I put new cartridge in
Follow this procedure to install print cartridges in you printer.
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the tape by using the pink pull tab.
Caution! Do not touch the gold-colored contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a upward slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
It must slide in at a slight upward angle.
Note: You must install both print cartridges in order for your HP Officejet to work.
6 Close the print-carriage access door.
“Press OK to print Align page” appears on the display.
7 Press OK.
Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Magenta print head reseat.
i'm sorry to be the bearer of bad news but it sounds like your carriage assembly is bad. the slot that holds the magenta cartridge is defective.have the carriage assembly and trailing cables replaced. this should resolve your problem. these parts are becoming harder to find because of the age of the printer. carriage assembly part number is C6074-69388. trailing cable is C6074-60418 making the assumption this is a 36" plotter. also you can try cleaning the contacts on the carriage assembly. good luck!
Sep 16, 2009 | HP DesignJet 1050c InkJet Printer
"set ink cartridge" message won't allow me to print
You may need a new carriage assembly, with the ink removed, with a mirror you can see down in front where the ink cart. circuit board contacts the carriage. Each slot should have 4 gold wires all of them straight. Bent ones can be straightened carefully, any missing, you'll need a new carriage assembly, a shop repair.
Jun 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Alarm says "wrong cartridge"
That happens when the print head sensor does not detect the cartridge.
To start unplug printer power cord for two minutes, and see if this can reset the error.
The wrong cartridge error may be caused also by a bad cartridge, therefore ,as first step you need to est a different cartridge, possibly a new original one.
Check also if the cartridge metal sensor inside the ink carriage is dirty and must be clean, in this case use isopropyl alcohol and cotton to clean metal contacts inside the carriage.
If that cannot fix the problem, then there is a lose connection on the wires connected to the ink carriage / print head assembly. TWhen that happens, the wires connected at the back of the ink carriage must be tested and eventually replaced.
Apr 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do a clear a carriage jam on a hp6210 printer
My HP6210 printer had the same problem. The carriage would make a lot of noise going back and forth and I got the carriage jam error message. Using a flashlight, I found an incredible amount of ink (mainly black ink) underneath the mechaism which clears the ink off the print cartridges. I throughly cleaned the internal components and it works again.
Mar 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to change a cartridge on c4345
Installing new cartridge:
Remove cartridges:
Nov 26, 2008 | HP Office Equipment & Supplies
Can I replace the PSC2210 print cartridge hold down lever?
The entire unit which holds the cartridge needs to be replaced. get it dont by some local tech shop.
Thanks
Nov 26, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
