Question about Vtech T2453 Cordless Phone
Phone can't find Base
MY V Tech phone can't find the base ..so I can't use it at all
SOURCE: searching for base
found the solution, unplug base power & take battery out of handset, then plug in base, and put battery back in handset, worked for me.
Posted on Feb 15, 2007
SOURCE: phones cant find base
I've tried everything to fix this. These phones last two years max. The only resolution I've found is buying a new phone system. I'll never, ever buy a vtech again.
Posted on Feb 04, 2008
SOURCE: phone not connecting
I find that unplugging the base unit power for about 20 seconds, then replugging it, usually clears this problem.
Posted on May 01, 2008
AvioriX
  • 689 Answers
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
  • 47 Answers
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Posted on Jan 06, 2009
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
How do i program a 6.0 detz phone to a 5.8 cordless base
contact V tech website for technical support but do not think it will work
Apr 02, 2015 | Vtech DECT 6.0 Digital Cordless Phone
How do you keep Base Unit of Vtech phone clean
Hello! Go to;
www.puremobile.com/vtech-cordless-phones.asp
This company offers a large selection of screen protectors ; Although none that are specific for your phone. Find a product that is close in size and trim to fit.
Guru.................saailer
Jan 06, 2010 | Vtech Digital Cordless Telephone VT-2568
How can I clear the previous registrations from the TRU 9485 base?
Use the following steps to reset the base to factory settings for all TRU models:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep).
According to Uniden Tech support, this is supposedly all it takes to reset the phone.
Aug 12, 2009 | Uniden TCX905 Cordless Accessory Handset...
I need help: my cordless Phone has lost contact with the base.
Place the handset on the base station for 10 seconds or so and it should re connect it. But if not you can look for the Base ID # on a tag under the base and enter it manually when prompted.
May 16, 2008 | Vtech Lands Phones
Phone issues.
1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
Mar 14, 2008 | Panasonic KX-TG5633B Phone
Ringer
Hold the Low volume key on the base unit for sometime. A beep will sound that means the ringer of the base unit is off.
Feb 18, 2008 | Panasonic KX-TG5632 Phone
Phone not connecting
I am having the same problem. Had it last year, too but bought new batteries for all the handsets and that fixed the problem. However, this year I can't find the batteries anywhere!
Jan 23, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Panasonic phone
1st) you must identify the ranking order of your handset. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset just now. Go to the main base cradle. On the bottom, where it says"locator" press the select button until you get the desired phone rank needed. H1,H2,H3 etc... Now, press and hold "call". (The charging light should start flashing) Now, on your handset press the "OK" button on the top upper right corner. Your phone should now be working! If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support.
Dec 23, 2007 | Panasonic KX-TG5633B Phone
VT ip8100 - enter base id problem
ya u need to contact v-tech vendor not vonage and gave them the serial no of ur handsets and get teh base id and try that will work
Aug 05, 2007 | Vtech INTERNET PHONE SYSTEM
Vtech T2453 Cordless Phone Logo
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
