Question about Sony KP-51WS500 51" Rear Projection Television
Your sony KP-51WS500
Did you get it working? and if, how did you do it?
Re-solder any bad solder joints on the D board (this board has the convergence IC's on it.) Replace the IC's with either STK392-560, or a better part which is STK392-570 (this part has been said to hold up better over the years).
Use only original SANYO convergence IC's and not the knockoffs made in China. The latter chips will ensure that you will be back inside the set within a month or two! So do yourself a favor, if you see these IC's on the Internet, and they are very cheap...beware. Usually these IC's cost $16 to $20 a piece, NOT less, like the knockoff IC's. There are several fuses around the convergence IC's (board labels PS8001-8006) and one near a transformer labeled PS8007. All of the convergence circuit fuses are 3.1 amps, 125 volts, and are made by Littelfuse (the 316 series) These are hard to find though, but are required for continued protection, i.e. DO NOT replace with a different value.
These fuses look like little resistors, except they are yellow in color, and have "3150" stamped on them. Test these with a DMM (digital multimeter) set to continuity check. If you find any of these fuses bad, please replace ALL 7 of them. Many factors can stress the fuses over the years, although uncommon, they have been known to open themselves for no apparent reason, UNLESS they have been blown by a bad convergence IC. Also, check any resistors around the convergence IC's for any failed ones. Replace them. You may want to obtain a service manual for this TV, as well.
Posted on Oct 05, 2008
What are resistors and where are they located in a sony kp-51ws500?
Resistors are present in this tv and every television set that has ever been made. These are a mandator components of the protection circuitry. If you can tell me what exactly the problem with your set is, I can give you specific advice to fix it.
Sep 26, 2011 | Sony KP-51WS500 51" Rear Projection...
I need part # for Sony KP-51ws500 D board, and
Required D board part number for KP-51WS500 is appended below:
A1300417A... D COMPLETE BOARD
Available in Part Store, click the link for price info.
Thanks.
Jun 04, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500
sony has a problem with that model the pix tubes short not going to be worth fixing
Sep 02, 2009 | Sony KP-51WS500 51" Rear Projection...
KP-51WS500 when on it blinked 4 times and has redscreen
Typically if you have a all Red Screen it is caused by either the Red CRT being shorted or The Red CRT Driver Board being bad.
Jul 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Checking if a TV is Hi Def
Yes, it is capable of 1080i.
http://esupport.sony.com/US/perl/model-home.pl?mdl=KP-57WS500&region_id=1
Mar 09, 2009 | Sony KP-51WS500 51" Rear Projection...
Have a sony kp-51ws500 need Blue Picture Tube
Try this link leave them an email with your model number and which tube you need they should be able to locate one for you.
http://servicemanuals.vstore.ca/
Apr 17, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
