Question about RCA Car Audio & Video
I would like to know how to hook up rca cord into a factory radio, so I can hook up my sub and amp without changing the deck. Is there a relay I need?..... thanks for your time........ Corey
    President:
  • 624 Answers
Not a relay, but a line level converter. You can get one at any place that installs car radios. You tap off your speaker wires and it brings the level down to the proper level for input to an amplifier. It has no appreciable drain on your speaker output so you would not even notice any drop in volume from the radio to the speakers it drives.
Let me know if you need any more help, and a FixYa! rating would be appreciated.
Thanks,
Dave
Posted on Jul 14, 2008
How do you hook up a subwoofer or a speaker box to factory stereo
Some radios on newer radios have RCA plugs tucked up in the wire harness to easily connect a sub amp. The sub amp you select will have the necessary instructions for hookup
Jan 22, 2017 | AMP Car Audio & Video
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
Jun 12, 2011 | Kenwood KVT-512 Car DVD Player
Were do i plug in the RCA cables from the amp to a factory radio? do i need any sort of adapters if my stereo dose not have inn or outputs? and where do i hook up the remote from the amp?
Most factory radios do not have RCA outs, but most will have a remote wire. Usually used for a power antenna option. Your remote wire from the amp could be hooked to the power antenna wire on the factory radio and it would work great for turning on the amp. As for the RCA inputs on your amp, you will not be able to use them without RCA outs on your factory deck. Although most amps offer a high level input alternative and will use the standard speaker level out on your factory deck. This means the rear channel speaker wires from your factory deck will be used to feed the signal to the amp. You will have to check the instructions and manufactorer recomendations for the amp you are trying to hook up. Have fun and good luck!
Mar 09, 2010 | Stingpro ST444 1850 Watts Complete...
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
Can't get my amplifier to work.
My homie had the same problem with his escalade they adapted an rca line adapter from the factory wiring to geta signal to his amplifier and it just wasnt hitting like it should so we installed a new deck and plugged the rca cords right into it and boomboom pow it was hittin like a champ-we figured that the stock premium system that was incoprporated into the truck had some sort of an onboard amp that was filtering the bass from the door speakers and which was limiting the bass output to the rca adapter and thus on down the line to the amplifier- so maybe ya might want to look into getting an aftermarket deck and see if that helps your cause-good luck
May 21, 2009 | Alpine MRP-M450 Car Audio Amplifier
I just got the Kenwood Sub KSC WA100 from my cousin with no electric wires or nothing so pretty much what all do i need and where can i find it i will be putting it in a 07 nissan sentra 2.0
Subs are subs, they come with no wiring. You need an amp and all necessary wiring to get it bumping. What type of deck do you have? Where will the sub be placed? In the trunk? Amp install is easy. Also suggest purchasing one of those amp kits for $20-$30, makes it a bit easier.
May 03, 2009 | Kenwood KSC-WA100 Car Subwoofer
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Jan 26, 2009 | Clarion DXZ545MP CD Player
Amp connection
The only amp wires that connect to the Head Unit are:
Amplifier remote turn on wire to Blue/white at radio
and RCA audio cords to SUB or REAR output RCA jacks.
Aug 04, 2008 | Pioneer 50W x 4 MOSFET Apple iPod...
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
HELP please!
ok on the factory radio there is an adapter kit you can get that plugs into the back of the headunit and will push the sound to the subs i had one in my car till i got a new headunit and it worked fine. id recommend that you go to your local sound shop like a detail shop or some place that installs them for a fee and ask them what you think
Nov 05, 2006 | AudioBahn A2300HCT Car Audio Amplifier
Car Audio & Video Logo
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeffrey Turcotte
Jeffrey Turcotte
Jay Plesset
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
