Question about Uniden : UN-GMR1558-2CK 15-Mile 2WAYRAD 2Pack RECHARGE 2-Way Radio
Gmr1558-2ck one of my radios has a beep when you push buttons and the other doesn't. how do i change the settings to make them both beep, or make them both silent?
    New Friend:
  • 109 Answers
Here is the manual for your radio http://uniden.com/pdf/GMR1558-2CKom.pdf
Posted on Aug 21, 2008
Set time clock radio for 2000 chevy venture
Push the "H" or "M" button until the radio beeps and then continue pressing either button to get to the right time. Push the power button on the radio to exit the time adjustment mode.
Mar 10, 2014 | Chevrolet Cars & Trucks
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
How to change the time on the Timex auto set clock radio.. the DST hasn't switched back to EST.
Timex T309TT Clock Radio.
Setting the time:
Unlike another review that says it automatically sets the time, I did not find that to be the case, I believe the model with the cd player does that, but this one had to be set. I'm not one to usually read the manual as I like to figure things out on my own, and was able to set the time without the use of it. It was as simple as holding the time set button and using the reverse and forward buttons to advance the time. Unlike some clocks, you do not have the option to change just the hour or just the minutes, you have to forward or reverse through all the hours/minutes.
Calendar:
The alarm can be set to go off 7 days a week, 5 days (Monday-Friday), or 2 days (Saturday & Sunday). Again, easy to do with pushing the date button and using the forward and reverse buttons to scroll through the dates.
Adjustable display: There are 3 levels of lighted display, pressing the snooze/dimmer button allows you to change between the three. Nice touch!
Radio Operation:
After pressing the Radio on the display will show the word "on" before returning to the clock display. The bottom display shows the radio frequency.
There are 18 programmable radio station settings with the buttons to access them right on the front of the clock labeled 1-6. Programming is easy with just finding a station you like and pressing and holding one of the preset buttons until it beeps to confirm it was accepted.
I find the radio to get fairly good reception and for the times it doesn't , after moving the attached wire antennae it would pick up a better reception.
So far my experience with the sound quality has been good.
The radio also has a last station memory, so after being turned off and then back on, will recall the last station you were listening too.
Alarm:
Setting the alarm is fairly simple. To set , simply press the alarm button until the time on the screen starts to flash. Then you can click the button to choose through 3 settings which are every day, weekends, or Mon-Fri. This radio also comes with nature sounds. I have not used this feature at this time. You have the choice of
* Ocean surf
* Forest spring
* Rushing brook
* Summer wind
Hope this helps :)
May 03, 2011 | Timex T309TT Clock Radio
CAN NOT CHANGE THE TIME ON THE CLOCK ON THE RADIO ON MY 2004 GMC TRACKER
procedures say to push and hold hour button for 5 seconds untill you hear a beep then set the hour by pushing one at a time sequence. same with the minute button ...hope this helps..good luck
Nov 26, 2009 | 2004 Chevrolet Tracker
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Sanyo DS25580
ah ok!
you mean your sensor in TV is not working?
ok ill teach you how to check the remote first... first get a radio and set in AM (amplitude modulation) then try to push the button in front of the AM radio, if you push the button of the remote control in the front of radio AM you can hear a sounds beep beep beep every push you can hear a beep. if you hear the beep sound the remote control is good.... if not its bad....
i hope you rate me as solved in premium thread
thanks!
Jul 16, 2008 | Televison & Video
Fr50 beep
Hello mtnrvr,
The Motorola TalkAbout radios, especially the FR50 and FR60, are notorious for making a variety of beeps when you push buttons and activate various functions of the radio.
The beeps can be helpful when you are trying to operate the radio in low-light situations. But they can also be mildly irritating.
Sadly most models of TalkAbout do not provide any way to disable the beeps. I'd suggest not using this particular radio for covert surveillance missions.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 12, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Radio Communications Logo
141 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
