Question about Husqvarna Viking 1
Sewing machine hi,I need to change the camstack,it is the main cam on the back the one witch old the decorative cam could you tell me how, the model is husqvarna 6460.also I have a kenmore model is 385-17926090 and the machine does not go back to make tack but it does make the back stich for decoration desing.tank you very much for the answer Huguette
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
My machine is not sewing the decorative stitches even though i turn the appropriate knob. what can cause this?
a gear or cam in the machine could be damaged, only having the machine checked could tell.
Mar 20, 2012 | Brother XL-3500
Cannot snap decorative stitch cam back in
What model machine are you using? If it is one of the 2000 series machines (might be labelled 6430 or something else but starting with 6000), from memory you need to align the knobs on the front to the "dot" before you remove or insert a new cam.
Jan 13, 2011 | Husqvarna Viking 1
Bernina 730 cam gear replacement and alignment
It does not matter where the position of the camstack is when you put it in, it should not affect any other part of the machine.
Jan 30, 2010 | Bernina Bernette 75
Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Jul 14, 2009 | Husqvarna Viking 1
Price and avaiability of cam stack and where from??
The camstack stack gear for your sewing machine runs about $110 you can find it at www.parts4sew.com
Apr 22, 2009 | Sewing Machines
Replace Gear Stack Cam on Bernina 730
This is a very common problem with these machines. First of all you have to have a new camstack gear. Then you may need a tech to do it. The gears can be found for purchase on the internet with a search. If you feel you want to do it yourself contact me and I'll tell you how but its very involved and many things have to be done just right for it to work.
Rick
Apr 11, 2009 | Bernina Bernette 75
Singer sewing machine model 2001
The camstack is not changing the stitches inside because of lack of lubrication
Jun 30, 2008 | Singer 132QRFB Mechanical Sewing Machine
Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Nov 24, 2007 | Sewing Machines
Sewing Machines Logo
290 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
