Question about Dishwashers
Thor PLS 602 broken left door hinge - Dishwashers
I put a 'piano' strip of brass hinge at the bottom of the door and on either side attached a length of brass chain - just like a drawbridge
will last forever
Posted on Feb 10, 2010
3 Suggested Answers
reddyanantha
  • 205 Answers
SOURCE: Thor PLS 602 door hinge broken - who can fix in
please visit the manufacturers website. there you will get the answer or find out any home appliance service center nearby and take the help from them.
Posted on Nov 06, 2009
SOURCE: where can i get a Thor PLS 602 dishwasher fixed
I have a thor pls 602 that i 'inherited' from my daughter who went overseas.
I dont need it - your welcome to it if you organise pick up etc.
Or any one else who reads this in the next frew days....
Im moving
Catherine 0413 424 778
Posted on Sep 13, 2010
How do I repair/replace a broken door?
Hello there, you will need a new hinge and probably the inside round piece of the door. Can you upload a photo? Please indicate the
E-Nr of the machine. You can find it on the label around the door and/or at the back of machine.
Jul 02, 2015 | Bosch Washing Machines
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
Trunk door hinge like x-bar was broken, what if i
dear friend-it will be ok to weld the hinge
Nov 09, 2009 | 2004 Volkswagen Passat
Nov 06, 2009 | Dishwashers
Where can i get a Thor PLS 602 dishwasher fixed the hinge on the door has broken. Washer still works I just would like the door to be right.
Im moving
Oct 19, 2009 | Dishwashers
Broken left hinge on lenovo sl4oo
try going on ebay for either hinges or anon functional laptop from the same manufactuerer and find the hinges. Good luck
Oct 12, 2009 | Lenovo ThinkPad SL400 Notebook
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Dishwashers Logo
393 people viewed this question
Top Dishwashers Experts
