Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
No drive letter
My WD my book would show as a external drive with a letter assigned and that was how I would back my files.I had unplugged it for a while and now it doesn't show on my computer with a assigned external drive letter. Now I can't back up to the WD drive. It is working properly. Why doesn't it show on my computer in device and removal storage? When I go to my computer and click on properties,hardware, device manager it shows my disk drives ARRAY and WD 2500JB external usb drive. It is working properly. My only problem is because a drive letter is not assigned and I can't backup.I need your help please. God bless.
  • 1 more comment
  • sonoran777 Aug 27, 2008
    I safely removed the drive however, if I go to stop the device, to disconnect the system shows it is in use, therefore I cannot unplug. Needless to say I have o drive letter or ability to access my data.
  • Anonymous Aug 28, 2008
    same
  • evinalis Dec 13, 2008
    same problem
  • 101 Answers
When remove the drive do this steps properly first when you want remove the drive remove safley than remive it
Posted on Jul 23, 2008
I plug in my WD external hard drive, i hear the chime saying the computer knows i plugged something in, but i see no icon to click on to open it. HELP! i have soooooo much information on this thing!
- try plug in a normal usb port (usb2)
- try open up the device manager, look for your WD and delete it.
then unplug and plug back.
try goto control panels->administrative tools->computer management->disk management
and see if your wd appears there. if yes, try change the drive letter assignment.
Jun 14, 2011 | Western Digital My Book 3.0 WDBAAK0010HCH...
When plugged into my computer, it acknowledges that it's been plugged in, however when i go to my computer to access my files, the folder doesn't show up.
Nalon:
Assuming that you're using Windows:
Assign a drive letter for the External drive.
  • Right Click on My Computer
  • Scroll to Manage
  • Select Disk Management
  • Locate the External drive in the lower bottom Right corner, Right Click, Select Assign Drive Letter. Ok/Close
Open up My Computer, and you should see your External drive with your new drive letter assigned to it.
Thanks for using FixYa.
Feb 13, 2011 | Western Digital My Book Essential 1TB...
The WD my passport is not recognized by the computer .. It was wroking fine couple of weeks ago and am pretty sure it didn't fall or something.. its not recognized and not showing on my computer .. please...
  • Scroll to Manage
Dec 31, 2010 | Western Digital My Passport Essential...
I just plugged it in and can't figure out how to save files on it. Please help.
1. check to see if the drive shows in the "my computer" window as a new drive letter or USB drive. If it does then....
2. Click and drag the data to that drive or in the "files" drop down menu click on "save as" then locate the drive in the save as drop down and save your data to that drive.
You will have to have 2 widows up to do so.
Apr 15, 2010 | Western Digital My Book Essential Edition...
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
WD My Book not displayed in windows explorer as drive letter
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Sep 24, 2009 | Western Digital MY BOOK HOME 1TB EXT...
Someone gave me a wd external hard drive. Computer says device is ready for use. Drive is found in device manager but no letter is assigned. All it shows is wd external usb device.
Since it an external device. dependent on the BIOS, some machine will assign a drive letter and some will not, either way, if the machine detect the device. you can use it as is.
Dec 05, 2008 | Western Digital My Book Essential Edition...
New WD external drive not showing up in my computer
I just had this problem, go to Computer Management/Disk Management, and assign a drive letter to it, for some reason it doesn't automatically.
Jul 16, 2008 | Western Digital My Book Premium ES...
Not showing my external hard drive
I HAVE SOLVED THE PROBLEM! or at least this works for my my book 1tb external hard drive. when i initially connect it i get the 'new device detected' pop up thing, but then it doesn't show on my computer. However, I have found that keeping the device pllugged into the computer but removing then replacing the power source from the device causes it to show up. That's all I did, unplug the power cord on the back and replace it. The computer says 'new hardware detected' and 'found my book mass storage device,' then it appears on my my computer tab. Hope this works with you as well!
Dec 04, 2007 | Western Digital My Book Essential Edition...
External Drive not recognized
Have you tried in Disk Management Right-Clicking on the drive and selecting 'Change Drive Letter and Paths...' ? That is the normal way to change or add a drive letter to any drive, internally or externally attached (other than by network connection)?
Dec 03, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
350 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
