Question about ASUS P4V8X-X Motherboard
Same problem, but not solved
Hello, i have the same problem, i bought a 200 gb samsung sata II disk, i put a jumper to change it to SATA I, but still my mother doesn't detect it. I flash the bios as you said, and then the mother detect de HD, all right untill I turn the PC off, when I start it again all the same message and the HD is not detected. So only detects it when I flash the BIOS, but then not.
Thanks for your help
Regards,
Matias
matmanr@hotmail.com
  • matmanr Jul 13, 2008
    I forgot to say that the problem is with SATA this is the message i got: "Hardware iniatiate failed. please check device The bios not be installed" and then what I told up there.
  • matmanr Jul 15, 2008
    Thanks, i would say that the SATA motherboard controller is bad, becaus I tested the disk in other computer and there was no problem. The thing is that I live in Argentina, so I don't that ASUS can give me support, but I'll check if there is other support for mothers here in Arg.
    Thankss
    President:
  • 2,351 Answers
Matias,
Please remove the jumper on the SATA drive. Boot to the bios & see if the SATA drive is listed. If it is you're good. If this is the first SATA you have tried in the Asus board & my suggestion also failed to show the SATA drive you are left with two options.
One the SATA drive is defective or the SATA motherboard controller is bad. You can call Asus tech M-F 8:00AM to 5:00PM EDT. At 1-812-282-2787, there is little wait time when calling Asus tech. Asus does not charge you for calling them.
Mike
Posted on Jul 15, 2008
  • Mike Peluso
    Mike Peluso Jul 16, 2008
  • Mike Peluso
    Asus supports their boards for three years. (Not by the time you bought it but from the date it was made). One of the oldest bios updates for you're board was listed back on 2003/12/02. I would say it's out of warranty by now.
Interface seagate barracuda 7200.7 200GB drive sata to usb 2 forum
Hello. You are correct that there are no jumpers, however, when you connected the SATA cable to the Internal hard drive, did you notice there were two similar connectors. One was for the SATA the other, longer one is for the POWER for the drive. If your SATA to USB has both connectors make sure they are both installed properly. Be careful you don't break those little plastic tabs because they are not warrantied. If the drive does have power and spins up then it may not be initialized (formatted) and will need to be initialized using START, Administrative Tools, Computer Management, Disk Management. or just click on start and type diskmgmt.msc in the RUN box.
Hope this helps..
Nov 04, 2012 | Seagate Barracuda 7200.7 200 GB Hard Drive
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Can´t find my SATA-disk....
I'm sorry to say buddy but I checked ... Then checked some more, and I can't see anything about your motherboard supporting SATA-II. If you look about you should find a jumper setting on your HDD to limit it to SATA-I, which is about half the speed of sata-ii but I'm almost promising it will work.
Let me know if this solves it, If not I can find the jumper settings for you, But seeing as though you just bought it you should have a manual.
Apr 22, 2009 | MSI KM4M-V Motherboard
P4VM800 SATA HDD Problem Plz Help me!!!
Your P4VM800 won't detect a SATA II (3 GB/s) drive, only a SATA I (1.5 GB/s). You basically have 2 options:
1. if you have a friend or colleague with a machine that supports SATA II, install the disk in that machine and us the manufacturer's utility to set the SATA to 1.5 GB/s (Seagate/Maxtor disks, but only these do have a jumper to do the job but SATA is in other respects jumperless). Then you can reinstall the disk in your machine.
2. Buy a host adapter card for SATA II and install it in a free slot in your machine - but may be better to put the money towards a new motherboard.
Oct 17, 2008 | Asrock 775Dual-880 Pro Motherboard
160gb samsung sata II
The PC is not seeing the Hard drive. check the jumper pin for the setting on the hard drive. If you have one HD then it should be set to master or cable select. Reboot and the cmos will see the HD. If not check the cables, and last check to see if the controller driver is installed for the motherboard. The controller is where the cable connects.
rmatheson@wowway.com
Aug 21, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Samsung 250GB HD250HJ SATA II.
Most likely if it makes sound then it is getting ready to crash, don't take a chance and remove your files and replace.
Jun 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Change of hard disk from 160 gb ide to 250 gb sata
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Jun 16, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS P4V8X-X Motherboard Logo
149 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
