Question about Maytag Atlantis MDG6400AW Gas Dryer
Maytag dryer won't light gas
It looks like the igniter has a melted spot on it like somebody hit it with a welder. either way, the gas won't light, what should I do?
Replace the igniter
Posted on Aug 16, 2008
I have a maytag gas dryer mgdx500xw, with door open and light on, circuit breaker blows, with door closed it does not, if I remove the bulb, it won't blow either way. Weird?
the return neutral wire from the bulb has to have a bare spot on it touching the metallic case somewhere in the dryer,when you remove the bulb you just isolate the bare spot on the neutral wire from the hot wire
Sep 07, 2012 | Maytag Dryers
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer mug15pdaww won't light, the ignitor
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 16, 2011 | Maytag Dryers
Burners won`t stay lit.........
There are several possible causes for this. Bad flame sensor, bad thermostat switch, blocked air vent, or bad gas coils.
This website
http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
Has very good troubleshooting and repair information for all of the possibilities
Feb 02, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Where to light the gas????
you dont light it manually it has an igniter operated by electricity off the control board
Sep 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag DG482 Dryer Won't Heat
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor
a%20igniter.jpg Ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils
part# 279834
The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks. SOURCE
Jul 07, 2009 | Maytag Dryers
Maytag Gas Dryer SDG515DAWW - heating stopped
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
Jan 03, 2009 | Dryers
My Kenmore series 80 dryer quit heating. It was intermitent for a few days then quit. I checked the inspection window and didn't see any light. The gas it on and it seems like there is a "click" after I...
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.6aed02c.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Dec 22, 2008 | Kenmore 659 Electric Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
104 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
