Question about Boston Acoustics BA735 Computer Speakers
Volume on/off potentiometer
Hello. I have a Boston BA735 that I haven't used for years. The volume/power control pot is bad now. If I plug in the power cord the power automatically comes on the speakers and the volume is full blast. Volume control can be manipulated when tinkering with the stem but it's unstable. Power can only be shut off by unplugging it. All else looks to be fine. I need a replacement pot but have NO idea where to find one. I've looked and looked but I can't find a suitable match. Need help finding this simple little part!! Thanks.
  • 2,130 Answers
You didn't mention where you are from, so it's hard to recommended a parts source. There are a few of variables here.
Such as:
1. The resistance value of the potentiometer.
2. The length and diameter of the shaft.
3. The shaft end determining what type of knob it will accomodate.
4. Physical size (depth & circumference with on/off switch).
You might try mcmelectronics.com but again, I don't know where you are located. Have you tried contacting the manufacturer's parts department and seeing if you can order the part?
If you can gain access to some tuner cleaner spray/electrical contact cleaner spray, you can try spraying that into the pot and see if it restores the volume control. The on/off switch is probably shot but it won't hurt to spray that as well. The spray is also available from mcmelectronics.com
Please let me know if I can be of further assistance to you.
- Jim
Posted on Jul 13, 2008
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
My Boston Digital BA735 speakers are not working. power is on. cords are correctly placed, volume on comp is not muted
Try to isolate the problem. Connect the speakers to another computer or mp3 player or stereo. Test the speakers for sound making sure all volume switches are on. If they work look to sound settings on your computer.
Oct 04, 2010 | Boston Acoustics BA735 Computer Speakers
I have boston acoustic speakers ba735 how do I hook them to my pc
if they have a usb connection or a 3.55mm plug plug it into the required outlet then control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers hope this helps
Oct 01, 2010 | Boston Acoustics BA735 Computer Speakers
Re: Boston digital BA735. Hum with or without input signal.
Hmmm I just got the same problem. They worked fine on my old Dell desktop but when I plugged them in to my son's old Dell PC (maybe 1 year newer than my old one) they all hum like crazy - as you say even if it's just the power plugged in and nothing else. Yes it does have the original power supply. I get no music (but still it hums) from digital out/in but when I switch to analog out/in I hear the music and it still hums, plus the sound is distorted. Wierd.
Jul 14, 2010 | Boston Acoustics BA735 Computer Speakers
How can i get the boston digital ba735 to work on my computer?
if now your computer not support this speakers,you must buy new soundcard support this speaker then build in to your computer hardware.good luck
Apr 28, 2010 | Boston Acoustics BA735 Computer Speakers
Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Mar 29, 2009 | Boston Acoustics BA735 Computer Speakers
Only one computer speaker recieving a signal
Most probably there is a problem in the cable or plug.
Feb 06, 2009 | Boston Acoustics BA735 Computer Speakers
BA735nalog
most probably a connection problem
Dec 18, 2008 | Boston Acoustics BA735 Computer Speakers
My Speakers went out and now all I hear is a buzz.
hello there,
First things First:
1) Check cables for dust, or bad connectivity. Clean aprop.
2) Clean carefully the volume control inside, with spray for computer use.(carefully inside the conectors)
3) Finally and sadly, have to change the speakers, may be is something damage inside the board of speakers, or fried. :o(
good Luck
Feb 06, 2008 | Boston Acoustics BA735 Computer Speakers
Boston Acoustics BA735 Computer Speakers Logo
811 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
