Question about Watches
Removing the back from a swiss navy watch
How do i remove the back from a swiss navy watch?  There is no edge to slide a knife blade under to remove back in order to change the battery.
  • Anonymous Jul 14, 2008
    I have three fossil watches and can't get the back off of any of them. How do you change the battery?
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: how to remove the back
First you need to determine if the watch is a snap back type or a screw back. If the watch back has a series of equally spaced slots (usually about 6) around it's perimeter, then it is a screw back and you will need a special tool in most cases. You can sometimes remove a screw back using a pair of snipe nose pliers in two of the slots, but unless the watch can be mounted safely in a small vice then this is quite difficult. The back from snap back watches can be removed with a blunt pen knife. If you look carefully around the edge of the watch casing you should see a small indent in the cover. This is where you start with the blunt pen knife, working your way around the edge twisting the knife gently as you go. Eventually the back will snap out of the watch casing
Just click below for more information;
http://www.pmwf.com/Watches/WatchSchool/WS%2011%20How%20to%20remove%20and%20replace%20a%20watch%20movement/WS%2011%20How%20to%20remove%20and%20replace%20a%20movt.htm
a youtube video guide sample on how to;
http://www.youtube.com/watch?v=ZMLZNclIcME&feature=related
Hope this may help you;
Regards,
VOTIT
DON’T FORGET TO RATE;
Posted on Sep 15, 2008
escapement
  • 2334 Answers
SOURCE: Repair of Ernst Benz Wright Brothers Centennial Watch
Yes, it is quite difficult to get the replacement parts from Switzerland and sometimes takes very long time. In my experience the longest was 9 months for the balance wheel.
If you are not satisfied with your watchmaker, check out direct services from Ernst Benz using this link: ernstbenz.ch
Here you can find all the info and services they are offering.
Do not forget to rate, please.
Posted on Feb 06, 2009
SOURCE: removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
Posted on Apr 23, 2009
SOURCE: Replacing battery on wenger swiss watch
Hate to say it but Wal-mart has the tools; seems like they'll do it for free if you buy the battery
Posted on May 28, 2009
  • 61 Answers
SOURCE: I changed the battery in my esq swiss watch and
ooh, ESQ by Movado. These case backs are often pressure fit, just like Movado, and are notoriously difficult to reinstall. It sounds like it is going to take a watch press to install your caseback. This is an expensive tool which any jeweler that changes batteries will have. There is no real safe way to this without a press.
Now, I have just supposed that this is a pop off; if it is a screw on back then it would have had to have been unscrewed to get it off. If it is a screw-back then you will likely need to get a caseback wrench to tighten it down enough.
Posted on Oct 19, 2009
How do I remove the back of this watch?
I have seen other burberry watches and the back should pop out .
1- Locate a very small tab or recessed area on the edge of the back cover 2- Pull out the stem, which releases the back on some watches.3- Get a small flathead screwdriver it needs to be a thin inflexible tip 3- Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). 4- When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. This information is on wiki: http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools
Feb 19, 2013 | Burberry Authentic BU1321 Womans Swiss...
Does the back cover snap-on/off or screw on/off? I don't see tabs for popping off.?
Although the cover is flatly closed and there's no tab/recessed area on the cover, you can still use a watchmaker's knife (looks like a Swiss Army knife but with case opener blade) or even use a Swiss Army knife to open it (pry off, particularly common in less expensive watch).
Be careful, don't try to use the point of the knife, use the blade instead.
Get under the rim and gently but firmly turn the blade upward, popping the cover off.
If the cover is flat, no notches on it, that is a screw-back case. You need a case wrench (screw-back watch case opener) to open (unscrew) the cover. If you try to use a very small flat screw drive and tab (turn) the cover in counter-clockwise direction, be careful because it can cut your fingers.
Hope it helps.
Feb 19, 2011 | Watches
Dont know how to change the battery in my callaway golf warbird watch
Thank you for contacting Fixya.
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • Pull out the stem, which releases the back on some watches.
  • Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Best regards. Jewel
    Aug 27, 2010 | Callaway Quartz Golf Watch
    I have a cat watch and i dont know how to get the back of so i can change the battery.
    Thank you for contacting FixYa.
    I am not familiar with Cat watches, but here are instructions for basic watch backs:
  • 2Pull out the stem, which releases the back on some watches.
  • 3Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • 4Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • 5Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • 6When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Aug 24, 2010 | Caterpillar (UB141344020) Wrist Watch
    How do I open the battery cover to insert the batteries
  • Aug 23, 2010 | Fossil Metal Dress Silver Dial ES1053...
    How do I take the back off of my Relic watch to replace the battery
  • Aug 20, 2010 | Relic watch
    How do i get the back off
  • Aug 17, 2010 | Cosmopolitan Wittnauer Men's Goldtone...
    How do you remove a watch back
    Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see. Pull out the stem, which releases the back on some watches.
    Or take to a local jewelry store/watchmaker!!
    Aug 16, 2010 | Ben Sherman Strap Watch
    Can't open the wrist watch case
    Use a Testor's razor knife with eye protection. Use as much of the blade edge as possible. The Testor's blades are fairly strong and thin and I have used them on many Skagens before. I have had some Swiss cases with no gap or tab and the tightest tolerances and the Testor's hobby knife blades were the only hope and solution. Please use care and eye protection for any repairs or service of this nature. Things break and fly off with great force. Including the blade of a knife or razor knife.
    Dec 03, 2008 | Skagen Watches
    How do change a battery of a watch?
    If you do not have the proper tools,(proper tools are recommended) and depending on the type of backing, this may help you :
    1. Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal.
    2. Get a kitchen knife with a rigid blade. It doesn't have to be razor sharp, it only needs to be inflexible. You can also use a small fine screwdriver.
    3. Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
    4. Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
    5. Locate your battery(Small round disc type) remove and check the numbers on it. Go to most any local dept. stores (Wal Mart, Target, Radio Shack, etc.) and purchase same.
    6. Install battery with numbers up.
    7. Place cover over watch, and snap back into place.
    Hope this helps. If not, please let me know and I will get back to you.
    Feb 07, 2008 | Watches
    Watches Logo
    167 people viewed this question
    Top Watches Experts
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
