I have vista home basic, And when i boot up it freezes with te status bar just not moving, I have Hard drive activity flashing at me but nothing and does not go any further, It lets me boot in safe mode, It lets me choose a resotre point, But during boot it freezes, I have attempted to boot in last know good config and nothing still freezes, Have re-installed factory state and still freezes
While in safe mode with network connectivity, go to trend micro website and do a free online scan. If you have Windows Defender updated, then try a full system scan, also while in safe mode.
Test all power and data leads that attach to your hard drive IDE,SATA the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios. Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system. Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd\dvd. Hope this helps.
if you have a boot cd for vista home then put the disc in drive - go to boot screen and change the boot order with cd/dvd-rom priority on top and go for the installation where you can format your system and install a fresh copy of Vista home.
make sure you have a bootable disc of vista home
Perhaps. It is a very old MB. Are you sure its the computer freezing and not just the video? After a cold boot, try forcing it to sleep with keyboard. If it does sleep wake it up. Does video work again?
To reformat the windows vista.There are two options to approach the reformat:
Option #1: Boot from the Windows Vista DVD. This is more complicated to do, but it destroys all data and partitions.
Option #2: Re-install Vista without leaving the desktop. This preserves the previous installation in a folder called Windows.old. Not all info is wiped, however, and you can't destroy your partitions.
First, restart your system. When the computer starts to boot, look for an option before you get to the Windows screen that reads: “Setup” “CMOS,” or “Bios”. This varies between manufacturers. For example, on the boot screen, it says: “F2 =Setup”. The option will flash by quickly so be ready for it and react quickly. You may need to reboot a few times to catch it. Once in the BIOS, look for a setting that says "Boot" or "Boot Sequence". You might have to dig through the menus with your keyboard’s arrow keys to locate the setting. In the listed as Boot Sequence. And to navigate to Startup, then Boot, and then Boot Priority Setting. When you find the setting, change your DVD drive so that it occupies the top of the list. The hard drive that contains Windows Vista should be listed as second in the boot list. And put the Windows Vista installation disc in the designated drive. Now, select the Save Changes and Exit option in the BIOS. The computer will restart and will attempt to read the optical drive you just assigned as the first bootable drive. The system will use the Windows Vista disc to boot and the reformat and reinstall process will start. But You will need to reinstall any programs that are not bundled with Windows Vista and reinstate your preferences and personal files after reformatting the computer and reinstalling Vista. Windows Vista Home Premium Edition upgrade Click here.This downloadable version of Windows Vista is an upgrade only. Users can upgrade to Windows Vista Home Premium from Windows XP Home or Windows Media Center edition.
If you purchased a computer with an installation of Microsoft Vista you would normally have a recovery partition. On restart continually press F8 to go to the advanced boot options menu and choose Repair your computer. If it would ask for language preference choose it. Then if it would ask for administrative access go ahead and login. On the next menu choose the image restore for your system. If you have a dell it would be Dell Factory Image Restore. It would depend on the brand.
If you installed vista separately. You would need to boot up your Vista Home Basic Disc. Place the disc in the drive and restart. It would normally load your disc if it is set as primary boot. If it did not enter the BIOS then change your boot sequence to start with the Optical Drive first or you could press the key for boot selection. some would press F10 or F11 for that, but you can find it when you boot up your computer. It would be stated on the starting sequence or the bios splash. Press that key and choose your Optical drive/CD/DVD drive. Then follow the instructions on reinstalling your Vista Home Basic.
The error code BI0HD-4 is a hard disk error. You need to delete all partitions on your hard disk and create new ones and format them
This will solve the problem.
Run diagnostics on the hard drive (Normally provided either in the F8 or F12 boot menus) and se if you get a failure.
If the drive passes diagnostics, boot to the Vista DVD and run the repair option. (Note: you may have to the Vista repair process 4 or 5 times if there are multiple errors to be resolved)
Nope diddnt work thanks for your help though
