I have an old but big (50" i think) SONY TV which was working fine until the day when i heard a little spark coming from the back and the screen went blank! the TV was still on but the screen was blank! and then a minute later the power light started blinking! i turned it off and tried to turn it on several times but it wouldnt work. a week later i got an electrician to look at it and he said the transformers gone and may cost £150-£200 to replace it! does the transformer really cost that much?? can i buy a second hand transformer from anywhere? is it worth changing it when i can add couple of hundred pounds more and get a new LCD TV? your advice/assistance will be much appreciated! thanks
  • 8,617 Answers
Please respond to this same post with your model number and I will post a link along with the part number where you can get a new replacement Transformer for a very reasonable price and they will give free tech support so you can Change it yourself.
Posted on Jul 13, 2008
Our large screen tv ( 2 years old and over 1000pounds from Dixons, UK) went blank. We switched it off immediately. On swtiching back on we heard a "pop" follwoed by the screen filling with dark...
Good Day, cjm364;
It sounds like the TV's panel has failed. A 2 year old TV should not fail in this manner. Call the manufacture and express your concerns to them very strongly and 90% of the time they will give a concession.
Good Luck, Big Irish, Let me know.
Jul 09, 2008 | Televison & Video
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
Mar 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Projection TV turns off for a few seconds
Good Day, boattech1;
To my understanding the Model 53UDX10B is a rear projection, that uses no fans. I think maybe your LAMP may be getting weak.
Good Luck, big IRISH.
Jul 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sony wega 61 inch (odessa, tx)
TV is a Sony WEGA 61" model # KDF-E60A20
May 28, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Black screen and no sound
I realized that there is a 90 day warrantee on parts and a 30 day limited warrantee on labor for the  repairs that were done. As I stated, the original problem was the picture shrinking after a few minutes of the set being on. The repair firm took my control board with them. When they came back to install the repaired control board in my set there was a load spark during the installation, after which I had a black screen and no sound.  The repair firm took my set them and installed a "CAP Kit", a STRM6511, and a "D1881". The set worked perfectly until two days ago.
I called the repair firm an they are coming out this Thursday to check out my TV.   I am hoping the problem is related to the failure of one of the parts installed to fix a similar problem which occurred after the sparking incident.
Mar 31, 2008 | Mitsubishi CS-40505 TV
Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever heard of this? Part runs about 300 bucks. TV is out of warrenty as it is 2 years old. Do you think it is worth it to fight sony and get them to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
Feb 01, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
SONY BIG SCREEN KP 61V80 "just shut off"
You will need a new Power/scan board unless you have some real good troubleshooting Skills. This is the ITC222 chassis it is not very easily diagnosed without the proper diagnostic equipment, It is going into protective shutdown. Replacing the entire module is your best bet
Jan 31, 2008 | RCA P60921 60" Rear Projection Television
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
