Panasonic Lumix DMC-FS6 Digital Camera Logo
Posted on Jan 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi sir, i cant download photos from the camera. When i connect it with the pc i just see an archive called "pmp_usb". This is the message that archive contains: "[ml_pmp] syncOnConnect_time=1273545644" No other carpet is active.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Panasonic Master 102,366 Answers
  • Posted on Apr 23, 2011
Panasonic Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10432107
Points
622693
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
1helpful
Olympus digital camera cant download photos from camera to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1helpful
When I Connect My Aiptek 8100 camera to the PC, they show a message "USB device not recognized." Is this because I did not install it's driver? If so please tell me where I can find the driver?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Windows XP compatibility
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 01, 2012 • Cameras
2helpful
2answers
When I connect the camera to my pc to download images, I receive "Communication Error" on LCD screen. How can I rectify...???
I think this page offers a good answer.
It seems to have something to do with the number of photos on your memory card. You should probably consider removing some of the photos you may have already downloaded. You can also use a USB card reader to get direct access to the card.
How do I transfer the pictures taken with my Olympus μ-5010 to my HP71-340US Notebook? I connect the camera to my PC's USB port, my PC recognizes the camera, I get the schematic diagram on...
You might want to consider NOT connecting the camera to the computer.
Jan 22, 2011 • Cameras
4helpful
When I plug camera's USB cable to computer to download photos, I get a "communication error" message on my camera's screen & can't download photos.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
8helpful
2answers
Purchased a Polaroid x800 camera and can not transfer photos to computer (and I have tried 3 computers - 2 running XP Pro and 1 running Windows 7). Upon connecting the USB cable it shows up as a removable...
Just did this with my daughter and it worked:
1. Turn PC on.
2. Plug camera cable into Camera.
3. Plug camera cable USB end into computer USB port.
4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'.
5. PC should be selected if not select by highlighting and press shutter button.
6. Press 'Shutter' button.
7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window.
8. Another window will ask you to name your picture folder. Give it a name.
9. The pictures download to the picture folder automatically.
10. Turn the camera off and disconnect cable from camera and from the PC
11. ENJOY!!
24helpful
3answers
Sony memory stick PRO Duo 2GB Pc will not display photos on PC
Hey all actual solution...sort of will get you your files well it worked for me.
i have winrar on my windows 7 pc but should work for anything with winrar.
  1. open my computer
  2. right click memory stick pro duo
  3. click "add to archive"
  4. in the winrar window under format on the left hand side of the window half way down select "zip" format
  5. click "ok"
  6. once your files have archived the DCIM folder and MISC folder will be in the archived file and should be accessible from there
  7. NOTE: you cannot extract files after the archive has been created DCIM folder and MISC folder will still be invisible even if you extract them from the archive.
  8. Files can still be drag and dropped out of the DCIM folder onto desktop or chosen destination from the archived file.
Hope this has been helpful to all reading this and everyone who posted the problem :D
IRIVER PMP 120
its just the USb isn't enough space for the usb port to fit in, thats all
3answers
XD card Problem
IF the images are lost (can't see them thru the camera), format the memory card (Photo mode button - Set - Format). These cards need to be reformatted frequently. I do it once a month, but I'd recommend it once every 500 pictures.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
