Question about D-Link Xtreme N DIR-655 Wireless Router
Security How do I set up the security for this router when I don.t have the disk?
  • 550 Answers
The router is web enabled, it contains a setup system.
from a lan cable connection, you dont want to lock down wireless from wireless, and lock yourself out if you make an error
http://192.168.0.1
and follow the setup wizards. the helpscreens are useful to expplain what & why you are doing.
Posted on Jul 14, 2008
Lost installer/set up driver linksys model wrk54G
You don't need the disk. You should be able to log-in to the web interface of the router at this URL: http://192.168.0.1/
If you don't remember the password, you'll have to reset the router to factory defaults and then log-in with password "admin".
Dec 05, 2011 | Linksys Computers & Internet
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I have installed 7ultimate and cant access my wi-fi .i have disk but it wont let me use my password says dos nt match. pressed reset to no avail
Make sure that the wifi security that you used on your router matches that of the security you are trying to setup on your new Windows 7 Ultimate box. If the security doesn't match up, it will tell you that your passwords don't match as well.
Aug 27, 2011 | D-Link DIR-615 Wireless Router
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
Need to set up my router (Belkin N Wireless Router) but cant find the disk that came with it. how do I go about getting it set up so I have wireless internet. Thanks for your help
1. Hold the reset button for 7 seconds when the router is powered to reset the router back to factory default.
2. Connect your computer to this router's ethernet port, type 192.168.2.1 on your browser's address bar then hit "enter".
3. You should see the Admin login page of this router, the default password is blank, it means you don't type anything onto the password field, just click "Login"
4. Make some necessary change, such as wireless keys, remember using WPA2 for security, not WEP.
Hope this help.
May 29, 2011 | Belkin Computers & Internet
If I don't have the disk to run the set up program for my motorola sbg 900 what can I do to set up my connection as a secure network?
go to this ip
http//:192.168.100.1
Defualt login: (if you did not set one)
user: admin
pass: motorola
and you will get the con-fig for the router
also here is the manual for this router/modem.
MotoModem
May 18, 2011 | Arris SURFboard SBG900 (49402201900) Modem
Have a router but not software for linksys, have reset the router but don;t know how to put in new password
Welcome to fixya
No proplem you don't need a software cd to secure the router. Please follow the steps
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts
Thanks
Vote me If it helps
Feb 07, 2011 | Linksys Wireless-G WRT54GS Router...
Set a security password
Start Internet Explorer.
Connect to the web-server "inside" the router.
Run the "Wireless Network Setup Wizard".
Enter a SSID of your choice.
Enter a security-password of your choice.
Jan 29, 2010 | Computers & Internet
Firewall/security
Most in home routers come with a disk to install ( more often than not norton ), If it didnt come with a disk you should go into the setting control of the router by typing in the ip adress in your IE bar, and clicking on the tab of security/firewall and putting them to the correct specifications. If that still fails for you, I would suggest going to the web and downloading a new driver for the router. Hope it helps!
Dec 30, 2007 | Arris SURFboard SBG900 Wireless Router...
D-Link Xtreme N  DIR-655 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
