My washer is not draining
I was on a chat a moment ago and my son closed it while I was in the garage. I've opened the washer, verified that the drain hose is not clogged, the fan belt is in good shape, the "iimpeller" moves freely and the switch is working.
The symptoms that initiated my request are the the washer filled up fine and went through the initial wash cycle fine, spinning back and forth. However, when the wash cycle was over, it failed to drain and go into the spin.
  • richardswork Jan 09, 2009
    my machine filled washed but won't drain or spin ..........fisher paykel IWL16
  • 41 Answers
Sounds like the pump is blocked or stuck
Posted on Jul 13, 2008
Maytag Front load Washer. "SUDS"
Clean the drain pump basket.
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
Water not draining completely.
Clean the drain filters: click on filters
Jan 24, 2013 | Kenmore Dishwashers
Oil is leaking from the drain plug. The plug is closed but why is it leaking?
Sounds like the drain plug is somehow staying open even though it is in the closed position. The cap is just to keep stuff from going in not coming out. I would either replace the drain valve or just get a brass plug and put that in it
Dec 25, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Washer code 5ud
Hello & Welcome to FixYa
Sud error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Dec 02, 2011 | Kenmore Elite 45986 Front Load Washer
My roper washer does not spin. The lid switch was replaced several months ago because it was not draining or spinning. Now, it drains, but does not spin. Any suggestions as to what it could be?
Check the motor coupling. It sits right between the motor and transmission. The coupling transfers power fron the motor to transmission. It is made of plastic and often breaks. If irs broken, the machine will drain but would not spin. Also double check the lid switch. Open and close the lid and listen for the activation of the switch. you should here it click.
Mar 05, 2011 | Roper RAS6233KQ Top Load Washer
My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
I have a Kenmore 80 series about 4 years old and it is leaking. Had a repair man over 3 months ago and it did not leak. However, I see my baseboard behind the washer pulling away and ran a small load...
check to make sure the drain hose is all the way in the drain pipe in your wall. there should be a strap, or tie wrap holding it in place to keep the water pressure from pushing the pipe out of the drain during the drain cycle. if not, the water pressure will cause the drain hose to rise up and allow water to leak down the wall. use a flashlight. you should be able to see a trail of water residue leaking down the wall. slide the washer out a bit and run it. see if the water is coming from the wall, or leaking out of the washer itself. let me know and we can go from there.
Nov 20, 2010 | Kenmore 24902 Top Load Washer
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
