Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Ice maker my ice maker quit making ice,I bought another one still no luck. I have checked the solenoid with 110 ten and it works,with a good water folw.
The arm on my ice maker somehow dislodged itself even though we do not put food on or near the ice bin.
Every time I thought I placed the metal rod into the proper hole. FInally I took a hand mirror and realized there is another hole further back that the arm was supposed to go into. It works fine now. Hope this helps you too.
Posted on Jul 15, 2008
My ice maker just quit making ice .I have checked the filter and it is in the on position.
Check to make sure that the water fill solenoid is working and allowing water into ice maker. If it is working check for ice in the tray. If tray heater is open the ice in tray cannot be scooped out and pushed into the ice bin. Also check for freezer temp - has to be at least 10 degrees or less in side for ice maker to work.
They are inexpensive and new ones can be bought on ebay. Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Refrigerators
Kenmore coldspot ice maker not working
check to make sure the water hasn't frozen in the tube that it should fill the tray with. Please let me know if this isn't the problem and I can further assist you. If frozen, you should thaw out the freezer to get it working again.
Good luck
Apr 11, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
We recently had a water supply connected to our Whirlpool refrigerator model GB2FHDXWB02. After ~ 18 hours no water has entered the ice maker? What is the problem? Can I manually initiate water going into...
Make sure you actually turn the icemaker on, there is a arm that you have to trip in side that will activate the solenoid that make water enter the ice marker. Also keep in mind that the air in the line has to work out so give it 24 hours to make it to the ice maker. You should see the hose in the back of the frig, that runs from the solenoid to the ice maker. Also check the ice maker itself to make sure it is plugged in completely. Good luck
Jan 09, 2015 | Whirlpool Refrigerators
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
My ice dispenser quit working
There are multiple components that can cause this.
Open the door and put your finger in the ice tray. Is there any ice or water in it.
If so then the problem is likely the ice maker.
If not then the water supply is either stopped up or the water valve solenoid is broke.
If their is ice then the ice maker may not be making ice for other reasons. Is the Ice Level arm down? If so, the Icemaker has a clock like motor that is actuated by a temperature sensor.
Ice maker calls for water, solenoid fills ice tray, temperature sensor gets cold over about 45 minutes and closes the motor circuit telling the icemaker to dump ice.
If everything is right and still doensn't make ice, some mechanical aspect or the icemaker appears to be broken.
Thanks for using FixYa, Good Luck.
Mar 03, 2011 | GE Refrigerators
Ice maker stopped making ice.
Check the line to be sure it is not frozen. If that is OK check the solenoid valve, that probably failed.
Good Luck,
Gilsh
Nov 26, 2009 | Refrigerators
Kitchenaid refrigeratorice make no water
When the ice maker stops to fill with water ,check if the solenoid (dual valve) gets power (110 volts) ,if it does and won't open you have to replace it ,but if it doesn't get any power ,the problem is the ice maker itself.
Sep 04, 2009 | Refrigerators
Ice maker arm rolls up and down butice tray doesnt fill with water
Hi, check to make sure water supply o/k. if there's water present, first check water solenoid valve, pull out ref. and disconnect your water connection, look inside solenoid valve, clean any debris from it, connect water and try ice maker, if it didn't work, disconnect water and check water solenoid valve, that's devise, where you make, your water connection, remove two wire from it(coil) and check coil for continuity, check for resistance with ohm meter, sometimes they burnt out. good luck.
Aug 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
Feb 14, 2009 | Kenmore Refrigerators
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
