Question about Seagate (9Y7275557) 400 GB Hard Drive
Hard drive not spinning up
Hi
i committed the cardinal sin of not powering down before i plugged in my 250 gig hard drive. saw a spark as i connected the power and have obviously cooked the circuit board. it now gets REALLY hot and doesnt spin up.
Can i purchase a new circuit board to get it operational to recover the data.
regards
Phil
  • 95 Answers
If it's not spinning most likely it has fried PCB or bad enclosure.
You can try to remove the internal drive from it and connect it directly to PC. If still not spinning then the problem is with logic board. Try to find another drive of the same model and replace the card. But as far as I know most often it doesn't work.
Here's some more info: http://datacent.com/datarecovery/hdd/seagate
Posted on Nov 07, 2008
Hi you would have to buy a replacement drive that works that is the same as the one you zapped and change over the board to see if you did any other damage to the drive motor or send it to a recovery person which would probably be cheaper in the long run.
peter
Posted on Jul 14, 2008
I have two hard drives.. WD 320 gigs & Seagate 250 gigs. Both drives are not booting. No sounds, nothing. I tried the freezer technique but not worth it. There's no clicking sound. I think the disc inside...
looking inside was a big error, that floods the internals with dust
the heads will now crash. but its dead anyway,, so no foul.
use your ears, not looking inside. gee. whirrrrrrr, try a good drive and listen, train those ears.....!!!
if it dont spin, or you can not feel the gyro effect (try that on good drive)
then the drive is bad. (or no power, +5v and +12v are mandatory)
you only said Seatage, they make vast types of drives, so I really dont know what you have, not really.
the drive (SATA/PATA but NOT SCSI or SAS) must spin up
with power, if not
1:bad power,
2; bad drive.
end of story.
ever held a gyro, like in boy scouts or? or NAVY.
it fights you when you ,try to change directions, of the drive case.
the gyro effect. all HDD do this., spinning at full speed.
is that enough help, if confused read an A+ book, all this is covered in one book.
if not pata/sata drives, the controller or drive must be commanded
to spin up. (servers use these drives)
Sep 25, 2013 | Seagate Computers & Internet
How do i transfer my data from my old la cie 80 gig 107443, to my new la cie 250 gig 300770? both boxes look the same, with the same connections [firewire, usb, 2 others].
Connect both drives to the computer at the same time. If you don't have enough USB ports, connect one to a USB port and the other to a Firewire port. Open a file management window (Explorer in Window, Finder in Mac OS) for each drive. Click and hold the left mouse button (only mouse button on most Mac models in the window for the 80 Gig drive and drag across several folders/files to select them. Release the mouse button, then click on and drag the selected group to the new drive window. When this copy operation is done, repeat with another group of files.
You could select (-A or -A) and drag everything on the old drive at one time, but sometimes the system will bog down on copying large amounts of data (greater than 4-8 GB at a time).
Mar 11, 2011 | LaCie (300770) 250 GB Hard Drive
My hard drive wont connect, and the computer doesnt recognize it.
hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
Western Digital External USB 2.0 Drive sometimes won't connect
problems like these are usually because of the usb connections, if the usb connection isnt strong enough i.e getting enough power,
try it on another pc if you can see if the problem persists
Sep 09, 2009 | Western Digital USB 2.0 External Enclosure...
Need power supply for Logitech Momo Racing Wheel
Power supply is 1/4" 24 volt dc (center pin positive) at 0.75 A.
GL on the allthread post.
Aug 25, 2009 | Logitech MOMO Force Wheel And Pedals Set
WD 250 gig ext hard drive
Hello there:
you may want to unplug the device for 3 min and hold in the power button or the reset button for 30 seconds and than power the device back up and see if this helps If not go to control panel and click on system and look for the device manager and see if it is listed there if it is click on the device and where it says remove say yes than click yes again than shut down and restart the computer and the found new hardware will start up and reinstall the device again for you. ok? please keep me informed how this is going,
best regards mike
Aug 03, 2009 | Western Digital My Book Essential Edition...
Upgrading from 250 gig hard to a 500 gig hard and says mismatch. my first hard drive is dead
hi pete,
changing the bios will do the trick, find one that is most compatible with aspire 1640 for a 500gig hd, once you have this replaced, it will work.
for more laptop troubleshooting tispd, you may also check the link below.
http://www.laptoprepair101.com/
hope this helps.
regards,
voodoo
Apr 12, 2009 | Acer Aspire L100 PC Desktop
Flashing Red Light
the drive is just connecting to your pc. now if it always stayed red, you'd have a problem.
Jun 06, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Upgrade Notebook hard drive capacity
hi there,
you Dell Latitude D610 can support large hard drives from 100gigs up to 250gigs ... but i very much think this is the limitation of your system bios if u are looking to go higer ... u might need to upgrade your system bios.....
Apr 07, 2008 | Dell Latitude D600 Notebook
La Cie External Hard Drive 160 gig
sounds like hd is getting hot via firewire try and use the usb lead if same problem then get your files off quick and repace drive any thing above 80 gig will get hot in use that's why I use harddrive coolers on my large 300gig 400gig internal and only use my 250 gigs and 160 gig only when i need the files off they are turned off all time
Jun 07, 2007 | LaCie (300740) 160 GB Hard Drive
Seagate (9Y7275557) 400 GB Hard Drive Logo
185 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
