Question about Sony KP-57HW40 57" Rear Projection Television
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
My television has progressively gotten worse over the last few months, the screen goes blue and it turns the picture off although you can still hear the sound. I am hesitant about calling a repair person becaue of the cost. Is their anything I can do to help myself? Thank you for your time and consideration.
  • lesleyx Jul 22, 2008
    Thanks, I finally have had to give in and call a repair shop. To my surprise when the pick up person opened the back of his truck to load my TV it was filled with large projection TV's of every size. I guess I am not the onloy one out here with an attitude.
I have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Posted on Jul 22, 2008
Describe your KP-57HW40 57 in. Rear Projection Television Problem I turn set on, screen along with image is blue, there is audio for a few seconds and then TV shuts itself off.TV bought in 2002. Can this...
Good day!!!
The problem of your TV is the color wheel..that is the one that affects the color if you had a dlp projection tv...
If your TV is crt projection the problem could be the convergence I.C (STK###)the common part #...
just replaced it with the same type,ratings and value.
Thank you and hope to solve your problem.
Sep 12, 2011 | Sony KP-51HW40 51" Rear Projection...
I have a Sony Color Rear Video Projector Model KP-57HW40. Its blue color is not working anymore and noticed some burn smell by the set which controls such blue color.
It may be the CRT drive board which is attached to the bottom of the Blue CRT. I would check that Board for signs of being burnt it may need to be replaced.
Jul 08, 2011 | Sony KP-57HW40 57" Rear Projection...
Image curve
Image curve, it seems tv got problem with convergence output ICs failure.
Do you get off color picture or like 3 pictures in tv screen?
Is it Sony KP-57HW40 rear projection tv?
Let me know above info to provide you helpful info to solve this issue.
Thanks.
Jan 17, 2011 | Sony KP-57HW40 57" Rear Projection...
Have Sony Model# KP-57HW40 Big screen rear projection tv..Has blue wavy lines across screen, and sometimes flashes blue, can you give me assistance??
Blue Picture Tube , bad Video IC on Blue CRT board.Or Blue screen drive control to tube needs to be adjusted down some.
Most Likely Bad Tube!
Jul 12, 2010 | Sony KP-57HW40 57" Rear Projection...
The screen is complete red how can I fix it
your red picture tube bloomed, because of internal short. you might turn down screen control on red picture tube it might help. always mark with fingernail polish your starting position so you can always go back. J.D.W.
Jun 25, 2010 | Sony KP-57HW40 57" Rear Projection...
Sony Projector Color Display
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Sony KP-57HW40 57" Rear Projection...
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40
Have a Tech. replace the focus/screen block if the problem continues you have a bad red CRT.
Sep 21, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
435 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
