SOURCE: Maytag Dishwasher will not start.
I had the same problem. The plastic wiring strip that connects the touchpad had corrosion from water. The panel would need to be replaced, because they don't sell the touchpad separately. (around $50 - $70 USD)
SOURCE: No Water in. Will not change wash cycles
There was soap particles caught under the float valve. Thanks.
Jim
SOURCE: whirlpool dishwasher adp 5966 6th sense delay start problem
you hold in the start button untill it goes off
SOURCE: MDBH968AWS3 THE AUTOWASH BUTON WILL NOT LIGHT AND IT WONT START
Lemme guess: First only one key failed, but OK, so we just use another setting. Then another key, then all keys but, say, AutoClean, but no Start, right? There is a ribbon cable connecting the keypad to a circuit board that corrodes from moisture, despite being "sealed" in a plastic sandwich. Imagine, moisture inside a dishwasher! As the corrosion progresses, it eventually breaks the connection to each key. Clearly a design flaw--Maytag has replaced this cable twice now (under warranty) in my first year of ownership, yet they continue to replace with the exact same part, and it fails in the exact same place each time.I fully expect this one to fail within six months or less. Only thing left is BBB.
