GM5424 computer powers up monitor says no signal vgb
  • breaker360 Jan 03, 2009
    my screen also says receives no signal. my keyboard isnt working at all either. this is right after i re-installed vista ultimate on my GM5424. it was working fine when i installed everything, but after u left it on to go run some errands i came back and i couldnt turn anything on. help please?
Computer monitor when powered on screen says"saving power" and shuts down?
Try to connect the monitor on other source for signal -laptop or other known working computer.if it posible.
Try with other rgb cable.Moust of monitor go tu stand by or power saving mode when is not presence of signal from computer(h-sync )
If monitor works ok on other source,than problem is in your computer(vga card probably)
Feb 08, 2014 | Computers & Internet
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
I have connected the cables....no display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
Replace power supply, computer on, monitor no signal, help
Did you forget to connect the 4 pin power plug to the display card or motherboard??????????
May 16, 2010 | E-Machines eMachines Desktop PC
Problem for LG 22" FLATRON Widescreen LCD Monitor LCD Monitor My monitor says analog power save and shuts off. Day before Yesterday I bought a new computer. I got the above mention problem on by...
The monitor is going itself to the Power Saver mode.It is not a problem of the monitor.This happens when there is no signal on the monitor.The monitor will display properly when there is an output signal on it.Please connect it to the computer and check that the output signals from the motherboard are proper.Also check both DVI (Digital Visual Interface) and VGA (Video Graphics Array)cables on the monitor.
Feb 23, 2010 | LG 22" FLATRON LCD Monitor
Losing signal to monitor
check all cable, and check you video card that it is seated correctly they can come loose ue to expansion and contraction
May 16, 2009 | Computers & Internet
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Video card for Dell 531s
This computer uses a PCIe-16 slot, so any half-height dual-monitor card with DVI would do for you. The XFX Geforce 7200GS with 256MB memory has dvi and vgb outputs. It supports the resolution of your 20" Syncmaster, and is around $40 at Newegg.com at this time.
Nov 04, 2007 | Computers & Internet
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
