Question about Lexmark X73 All-In-One InkJet Printer
Lexmarkx73 Won't feed paper through while printing
When try to copy something. The scanner works but the printer always jams or doesn't feed the paper through. I push the paper feed button and the paper comes through, but not while it is printing. Why?
  • jmarti01 Feb 26, 2009
    Printer feeds but will not track thru while printing ...
    If I shut printer off, then turn ON
    I can manually advance paper .... while "jigging the partially loaded paper" ...
    I realize the X73 is no longer manufactured ... finding parts may be near impossible.
    I haven't taken the printer apart yet .. if there is another way to resolve this issue.
  • Anonymous Apr 23, 2009
    I had same problem and found that there is a thumbtack stuck in the printer feed area. How in the world do I get it out?
My lexmark x73 makes a clicking sound while printing and paper does not feed correctly
Posted on Mar 08, 2009
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jul 26, 2008
The clicking is a broken roller drive gear. It is visible with the cart. door open and look at the left side of the paper feed roller. You can see the gears turning but the roller gear is broken so it clicks as the next gear hits the gap in the broken gear. This is also causing the paper feed problem due to the broken gear is turning but is no longer turning the paper feed roller. If anyone knows where to find this gear or ***'y please let me know. Mine is broken too.
Posted on Jul 22, 2011
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
Paper won't feed through to the printing area
If when you mash print and the paper doesn't move through to be printed on it may be because you don;t have the paper inserted properly or maybe someone jammed your printer and tried to unjam it the wrong way and didn't tell you....hope it helps
Nov 16, 2011 | Office Equipment & Supplies
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
I've got an HP R40 multifunction printer. Yes, it is old, but it don't know of another printer out there that will do what it does. I'm having a problem when I try to copy something, it will scan the...
I had the same problem and HP claimed it was the roller on the feed unit. I do think they are programed to feed a little different for scaned documents than copied docs. HP gave me a new printer worth more rather than even try to fix it. Here is a tip. Take the insurance on the extended protection especially if you have a 4 unit function (fax, scanner, copier and printer) chances are 1 function will break before the end of your extended protection. You always get a new unit, rather than them fixing it. It's really worth the 50 bucks if you buy a high end unit.
Aug 10, 2010 | HP OfficeJet r40 InkJet Printer
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
My adf jams. It does not feed the paper through it is missing the exit slot and jamming on the scanner. Is my scanner light spposed to always be on when the clover is closed? Thanks Richard Earle
Yes, the scanner light is normal always on, even if the cover is closed.
Try cleaning the rollers with some water.
Check if there is a piece of paper or staple or something else in the paper path.
If still jamming you need an engineer to service your ADF.
Please use the platen mode to make copies
Good luck and please rate me, thanks.
Jan 21, 2009 | Brother MFC-8840D All-In-One Laser Printer
I replaced ink and paper..paper keeps jamming when printing and copying. after the replaced inl and paper, i was able to print with no problem however without warning iunable to print or copy without...
Oct 20, 2008 | Lexmark Office Equipment & Supplies
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
Lexmark X73 All-In-One InkJet Printer Logo
937 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
