Question about Frigidaire Washing Machines
When my front load washer is in final spin it shakes and bangs really bad what can it be?
    Genius:
  • 1,122 Answers
Alot of the time it because the washer to full or the washer might have gotten unlevel,check both and let me know,thanks-mike
Posted on Jul 13, 2008
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Loud noise during spin cycle
Open the cabinet top and check along the sides for a broken or out-of-position damper. Shake the mechanism in several directions to help locate. Hope this helps!
Jun 12, 2010 | Kenmore HE2 Plus Front Load Washer
MY WASHER IN FINAL SPIN STARTS BANGING OR SLAPINING LIKE A BAD BELT OR SHOCK, BUT THEY LOOK OK [ NO DAMAGE TO BELT / ADD, PREASURE ON TUB DOES NOT HELP ] NOISE IS ONLY ON HIGH SPEED OF FINAL SPIN FRIDG. #...
it could be 2 or 3 things wrong here 1 could be something as simple as an uneven load that would make the machine jump about and bang,it could also be the drum spider this is internal to the tub it holds the drum onto the drum shaft this could be broken or it could be one of the counter balance blocks as become lose all three would only really show when in high spin gd luck
Oct 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Shakes violently and bangs on spin
transit bolts not removed. also can be caused by motor not winding up gradually into spin - usually a motor tach fault. most likely cause is transit bolts
Oct 18, 2006 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
43 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
