Question about Tecnik TKC1285 Dual Fuel (Electric and Gas) Kitchen Range
Tecnik TKC 1285 Access to Fan Element
I think the element to the fan element to the main oven has gone. I'd like to replace it but cannot see how I gain access to it to do this. Is it through the back of the oven compartment, or from the rear of the oven itself??
Advice would be really appreciated. Thanks.
  • Anonymous Nov 28, 2008
    First turn off the main switch for the cooker
    You access the element by removing 4 screws located on the backplate inside the oven.
    Then pull out the oven to access the rear.
    Remove large rear backplate.
    Peel back insulation to access a large plate that has the fan located on it.
    Remove 4 screws holding that in place.
    You should now be able to remove the element.
    £19.45 from Element Replacements.co.uk
    President:
  • 1,462 Answers
Both. element is usually held by 2 7mm nuts on posts from element base plate which are accesible from rear plate. element comes out into the oven cavity
Posted on Jul 14, 2008
Main oven element in tecnic tkc 1285 how do you replace it
tecnic tkc 1285 blew rcd. now large oven only heats up to around 160c takes forever to go higher .Top element glows. is there another element or is it the stat.?
May 02, 2013 | Ovens
Tecnik Range dual fuel TKC 1285 (more than 10 years old) The timer clock doesn't work so we cannot set the timer for the oven to come on later in the day + Our oven doesn't work when we...
No you can replace timer or bypass it to make it work. I can source parts for you I and fit if required. David 'The Famous Forry'
Oct 20, 2017 | Tecnik Ovens
Can you replace oven element, cannot see any screws in oven to remove plate to gain access
You will have to remove the oven from the housing, and then remove the rear cover of oven, and gain access to the securing screws for the element from the rear of the oven, you will see how it is fixed once you remove the outer panel of oven
Feb 23, 2011 | Candy FP855 Electric Single Oven
Replacing element in the oven. Can you do it from the inside
On most ovens it is generally just a matter of undoing 2 screws inside the oven to release the element bracket. Wiring terminals can then be accessed. If it is fan forced and the element is surrounding the fan you will need to take the fan/element cover off. If the element is beneath the floor of the oven you will need to take the back off the oven to gain access.
Feb 17, 2011 | Whirlpool Kitchen Ranges
I have a Tecnik TKC 8522 double oven - I can't get the bottom oven to heat up. When you turn it on the fan comes on, but the red light doesn't come on and the oven doesn't heat up.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
Sep 25, 2010 | Tecnik TKC8522 Electric Double Oven
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Do you know the power rating of a TECNIK TKC 1255/SS cooker
i believe this is a range oven so has gas hob top one large oven a one small oven main oven draws around 2.5 kw on fan and 1.8 on conventional elements.
May 17, 2010 | Ovens
The main oven of my DY46 Hotpoint is not heating up
It will be the element that has gone, and it is easy to replace.
Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
Feb 22, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Kitchen Ranges Logo
1,065 people viewed this question
Top Tecnik Kitchen Ranges Experts
Shehu Pro
Shehu Pro
dik stukkien
dik stukkien
JonSnell Electronic
JonSnell Electronic
Are you a Tecnik Kitchen Range Expert? Answer questions, earn points and help others
