Question about Samsung Televison & Video
Samsung model LNT4032HX/XAA There is dark areas in the screen seams to start at top and going down and drifting to the right, could this be something to do with the liquid crystal
  • dbsmith459 Jul 13, 2008
    this is a LCD t.v. the t.v is about 1 year old or less. It has some dark areas in it that I can only describe as if you seen rain coming down way off in the distance and as it moved along the bottom area would start to angle back. Someone told me that the LCD could be leaking down.
    President:
  • 2,712 Answers
No, its more likely a problem a problem with the vertical/horizontal amp..You need to get that replaced..
Posted on Jul 13, 2008
  • Swilin Sampson
    Swilin Sampson Jul 13, 2008
    If it were a problem with the LCd, if you touch your finger on the screen even slightly, youd get a big smudge..
  • Samsung Master
  • 19,396 Answers
Well, if it is a projection TV there should be no Liquid cristal display.
  • Ginko
    Ginko Jul 13, 2008
    Seems more to be a problem with alignment.
  • Ginko
    Ginko Jul 13, 2008
    If the LCD is leaking the stains appear like dark liquid stains, they expand slowly but they do not move the way you described.
    Sounds like a fault in the pcb board, a fried IC or so, when LCD display is faulty it is dead, or display bands, or rather static stains from fluid.
    If it is less than one year old check guaranty terms.
    If you want to DIY, the only simple operation is removing the cover and checking the LCD connector.
    Even this operation should be done by a technician.
    The rest involve trying some service setup procedures, testing the board and following service manual, if you do not find anything weird on the board you test a replacement LCD display.
    The whole operation must be done by an expert technician.
    In the last pages of your owner manual you should find phone contact and instructions on how to get service and check warranty.
    Or find contact on Samsung website.
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Dark screen on samsung lnt4669fx lcd tv, what could be the problem?
As you suspect, it might be of T'Con board fault. Check all the flat cables connected to T'Con to panel should be checked first for any loose contacts. Re-seat them once. If you wish to know more, check this site. It has illustrations of screen shots, for Samsung LCD TVs, with a faulty T'Con board. Can compare these images with your TVs.
Jan 24, 2013 | Samsung LNT4669 TV
Samsung HDTV - HLR5067WAX/XAA - popped, went dark
You had a surface mounted capacitor (AKA "CAP") let go on one of the circuit boards, open the set up and look for a small burnt area on the circuit boards inside the TV, it is likely it will be the power supply board, but that is just a guess..
Apr 13, 2017 | Vivitek Televison & Video
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
I have a Samsund LNT4032HX/XAA i need to find a oem base/stand and cant find one. do you know where i can get one or what the part number is?
the easy way to find one is going to a tv repair or call , and have then macht one for u , the part # is BN96-03697B
Nov 03, 2010 | Samsung LNT4066F 40 in. LCD Television
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
Need to take case off dryer there is something stuck inside because kids dried with lint screen out
SOMETHING IN THE BLOWER WHEEL CAUSING A OBSTRUCTION AND MOTOR WILL NOT START. START AT THE TOP THEN FRONT WILL COME OFF
Apr 29, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Televison & Video Logo
103 people viewed this question
Henry  Thomas
Henry Thomas
