Question about Nostalgia Electrics CCP-509 Popcorn Maker
Pop corn jamming in the kettle
Hi!
When I'm doing pop corn in my machine, it's start popping in the kettle and suddendly jams and stay in the kettle
  • 6 more comments
  • jul_2222 Sep 21, 2008
    I have the same problem! And I'm using the correct packet size for the kettle size. It just all gets stuck in the kettle and doesn't come out, and about half of the kernels are unpopped.
    Somebody help!
  • rhonda f Oct 07, 2008
    I have the same problem. I think the stirrer rod pushes up and popcorn gets stuck under it.
  • the-allens Oct 11, 2008
    We are having the same problem. We notice after it happens that a kernel is stuck under the stirring rods so we are thinking the same thing that the rod is too loose and raises.
    To the suggestion that we are putting too much in at one time...we tried putting half the amount in popping and doing the other half, but same result on the second half.
  • ellynn60 Dec 12, 2008
    I am having the same problem and my popcorn maker never did this before (I've only used it about 15 times) and all my popcorn and oil packages are all bought pre-measured by the company I bought the popcorn maker from.
    I have the very same problem, my maker just started to do this recently (it is a new popper) all of my popcorn/oil packages are all pre-measured from the factory where I bought the maker. PLEASE HELP
  • darlinn Feb 11, 2009
    Too much popcorn is not the problem. The stirring rod is sliding up allowing kernels and popped corn to get stuck. My husband is going to try and move the bolt thing, on the underside above the spring, down to keep the rods from moving upward.
  • Anonymous Mar 20, 2014
    popcorn is rubbery instead of chrunchy. Should I be using the black lid while I am popping?
  • Anonymous Mar 22, 2014
    Can't do nuts or coffee and sometimes in the middle of popping corn
    Sergeant:
    Champion:
  • 417 Answers
This happens if you put took much in at a time
Posted on Jul 17, 2008
Don't have a manual need to know how to operate Do I add oil or butter in bottom with the corn if so how much?
the ratio for popping corn with oil is three parts corn to one part oil . So a 6 oz kettle you would use 6 oz of corn seed to 2 oz of oil. Don't use butter to pop, it will burn.
Apr 27, 2016 | Kitchen Appliances - Others
Why is it taking a long time to start popping, not popping completely, and leaving excess oil?
Sounds like the kettle isn't getting hot enough. The thermostat is usually at fault in this situation which can be determined by checking the amp draw on the kettle. the common complaint is the kette is too hot and burning but what really is going on is it's not hot enough so the seed won't pop. Because of the heat that is there it will loose it's moisture, dry out and burn instead. You will end up with lots of old maids . Really stale corn seed will act the same way because all the moisture in it is gone and thats what is needed to pop it.
Feb 14, 2016 | Gold Medal 2121 Econo Popcorn Maker
Popcorn doesn't pop to full size. The problem is, the popcorn pops however the sise of the opoed corn is only one quater the sise it should be.
Not enough heat in the kettle to do the job. The corn will dry out and pop poorly when there is not enough heat. Either a thermostat adjustment or replacement or a bad element.
Feb 01, 2014 | Cretors Kitchen Appliances - Others
Popcorn machine model tpc-603 manual
Treat Time Model TPC-603
Turn on light and popcorn buttons, for 2 minutes to heat up the popper's kettle.
Then turn off the popcorn button, this stops the turning gears while loading oil and popping corn.
Warning the stainless steel kettle will be hot. Might want to wear an oven mitt.
1 tablespoon of oil (I use coconut oil) and 1/3 cup of popping corn. This makes est. 6 to 8 cups of popcorn.
NOW turn on the popcorn button so the gears start turning, this turns a wire on the bottom inside the kettle to keep the kernels from sticking or burning to the bottom.
If making multi batches, during the process it states in the manual to allow it to cool 5 to 10 minutes. I normally pop 3 to 4 batches and then let it cool down.
When finished popping, turn off both the light and popcorn buttons.
Dec 28, 2012 | Kitchen Appliances - Others
Our elementary school has this Gold Medal 2213 Antique *** 90 Popcorn Machine. We don't seem to have any manual for it now. We would like to use regular corn oil and kernels, versus the all-in-one bag...
Generally, you want 3 oz. of corn to one 1oz of oil. The amount of corn you can put in the kettle depends on the size of the kettle. So take the kettle size, (I think that machine is an 8 oz popper) and divide 8 by three to get 2.66 oz. (about a third of a cup) of oil needed. So you would use 1 cup of corn, and a third cup of oil.
Feb 23, 2011 | Gold Medal 2213 Antique Gay 90's Mega Pop...
I have a Star model 89, manufactured in about 1986. Its a 14 oz kettle, and everything works, however the kettle will not pop the corn. The kettle is hot to the touch from the outside, but will not pop...
Make sure your agitator arms are properly functioning. If the corn is not being properly stirred, it will not pop. Also, make sure you are using the correct type of popcorn oil.
Nov 04, 2010 | Star 39 JetStar Popcorn Maker
ALL THE KERNELS ARE NOT POPPING
There are several possible culprits for your Kernel Caper.
1) You may need to add a little more oil to the kettle. Let it come to full heat--just as soon as the oil starts to smoke.
2) The corn you are using must be reasonable fresh and have sufficient moisture to pop the kernel. You can try putting 1 tsp/1 lb of corn in a ziploc bag or screw top bottle. Leave for 24 to 48 hrs to let the corn absorb the moisture.
3) Finally, due to the small size of the popping kettle some kernels will be thrown from the kettle from other kernels popping open.
This is a great little popper. You might have some luck decreasing the size of your batch--reduce your oil and corn by 1/4 each.
Good Luck
Sep 24, 2010 | Maximatic EPM450 Popcorn Maker
Ccp-509 popcorn kettle stop spinning when popcorn begins to pop. It won't pop out of the kettle.
Normally that is caused by too many kernels used. It pops too fast and jams up in the kettle. It could be a problem with the kettle though. Call 920-347-9122 for help with it.
Feb 13, 2010 | Nostalgia Electrics Helman Group CCP-509...
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Popcorn jamming in kettle
The only real solution is to put less kernels in kettle - it pops so fast that it jams up and burns. Adding a little more oil usually helps as well.
Dec 12, 2008 | Nostalgia Electrics CCP-509 Popcorn Maker
Kitchen Appliances - Others Logo
382 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Wayne Fellows
Wayne Fellows
Shehu Pro
Shehu Pro
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
