Question about Toshiba 32A40 32" TV
Toshiba 32A40 32" TV Problem
A few weeks ago my tv picture went bad.  When I turn on the set, there would only be a thin horizontal line across the middle of the screen.  The sound was fine.  After about 30 minutes the picture would fill out and there would be no other problem.  The color would be fine, the screen would not exhibit any rolling.
I think the tube is gone and probably needs to be replaced.  I've checked on line and this seems to be a fairly expensive solution.  Could it be something else or should I just look for a new tv?
thanks, peter.
  • 1 more comment
  • Anonymous Aug 30, 2008
    I have the same problem, usually banging on the side of the tv helps but the next time you turn it on the same problem occurs.
  • fasteddie196 Apr 01, 2009
    same problem, just a skinny line across the middle. Banging helps temporarily but does not fix the t.v. It is also getting hard to fix by banging the side now.
  • jpolega Apr 25, 2009
    Same problem as above (sound okay, thin vertical line in middle of screen temporarily fixed by banging side of t.v.) anyone know what is wrong with it and how costly to fix?
Does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Posted on Oct 25, 2008
Hi I had a videoconlcd TV some mistakes the TV color went plasma how to solve the colorproblem tell me menu setting
It is so intersting to note. Color TV turned to a Plasma TV?
Hai. What I'm seeing!! Strange indeed!!!!!!!
Jan 12, 2017 | Televison & Video
What to do when your Toshiba 55TL515U powers on, works fine for a few hours, then suddenly turns off, and then continues to click as if it is turning on and off again?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 11, 2017 | Toshiba 55TL515U 3D LCD TV
Have a dark band horizontally across vizio tv. Appears to be a backlight, but not sure how to fix
Could be a bad CCFL lamp, if the set usess CCFL back-light system. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 08, 2017 | Vizio Televison & Video
Sharp lcd tv. Grn lite flashing, reset by unplug, vol + ch - , plug in. Tv came back on, after few mins screen goes blk, have sound. turn off and on picture back for few minutes, goes blk, snd ok.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 07, 2017 | Sharp Televison & Video
My Toshiba 46g31ou tv keeps shutting itself off and on by itself.
MUST BE IN THE SETTINGS OF YOUR TV WHERE YOU CAN CHOOSE TIME FRAMES FRO IT TO TURN AND OFF ITS A POWER SAVER FEATURE
Nov 30, 2016 | Toshiba Televison & Video
Tcl tv line through screen
maybe vertical ic be came hot and make some lige unconnected in board have to go to tv tichnican
May 18, 2013 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
My tv has gone some orange colour
Try unplugging your tv and anything connected to it - you might want to take a picture first so you have a reference. I would also unplug everything connected to the tv: cable, stereo, etc. Wait a few minutes, then plug in and re-connect everything.
You can also go into your TV's setup menu and adjust the picture settings - try restoring the default settings first.
Mar 22, 2013 | Televison & Video
Toshiba 32A40 32" TV Logo
505 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
