I have a Westinghouse tube radio, AM/FM table model, uses a selenium rectifier. I need a schematic for this radio, do not have a model number, but chassis number is 240635. Would appreciate your help.
  • driggins Jul 14, 2008
    Robotek,
    Thanks for your reply, the 240635 is stamped on the chassis and is identified as a chassis number. This radio is in a plastic case and the model number appeared to be on the bottom of the radio in paper, but the attached (glued) paper has been removed. Where would I be able to find a schematic with this limited information.
    Thanks for your help and I hope you have a sterling day,
    driggins
  • 1,512 Answers
Hi driggins
Wondering if that may be the serial number that you have quoted. Most Westinghouse radios that I have been able to find are allocated model numbers as WRXXX
If it has a solid state rectifier then it will be post war vintage at least.
Are there any other identifying marks on the radio?
regards
robotek
Posted on Jul 14, 2008
  • Graeme Ross
    Graeme Ross Jul 15, 2008
    I guess that I wonder what you are needing the schematic for? MOst vintage Tube circuits are relatively the same. Fault finding comes down to experience with what voltages you see where. In general, if it is in original condition, it will have many leaky paper/wax capacitors, composite carbon resistors that may have doubled in value. These are generally the things that stop these old girls from working. Are you wishing to restore the radio?
    robotek
Free schematic diagram
You may not be able to get a schematic. You need to be able to troubleshoot electronics without a schematic. Check where the AC cord connects to the circuit board. In general there should be a fuse and a transient suppressor. Next will be the transformer if there is one or rectifier diodes. These usually fail in a lightning strike. There is also the probability of other component failures, but you won'y know that until you repair these components.
Sep 01, 2014 | Sound Around Pyle Home PTCDS2UI AM/FM...
The whistle on either side of my 1966 lionel zw transformer does not work
The contacts on the switch may be dirty but the most likely problem is that both selenium rectifiers are dead. Replacement silicon rectifiers are available if you want to do the repair yourself. Check the internet for suppliers. You can get the ZW repaired at most good Lionel service centers for a reasonable price. Get a list of service centers by searching on-line or at Lionel.com.
Mar 05, 2014 | Crafts & Hobbies
Finding Marconi radio schematic model79-c
If it is a 791 instead of a 79, check here:
http://bama.edebris.com/manuals/marconi/
you may find a similar model.
If it is a Marconiphone,
http://www.nostalgiaair.org/Resources/246/T0000246.htm
Although there were some Marconi models that may not be int he Nostalgia Air database for any number of reasons, partly due to the fact Rider usually put them in with the Miscellaneous models.
Other possible sources could be in the various "Shortwave guides" that were published in that era- many included schematics from the manufacturers. Lindsay publishing has reprinted 1936 and 1937, whether they are still available is tough to say, but you can check the listing of what Lindsay publications has on hand at http://www.lindsaybks.com just look for the book list.
My own suggestion- Recap it completely first. Then check the resistors to make sure none are outside of the tolerances- usually 20 percent. From there, tweak the IF;s and the radio should come to life even with weak tubes.
If you are in the UK, or Europe, there should be a few dedicated museums that may have the schematic available as well- just use search engines less used. In other words- forget google or bing- Although google.de or google.it might give you some hits if the radio is not of US manufacture.
Feb 16, 2012 | Radio Communications
I need a schematic (wiring diagram) for a Westinghouse RE391S-R fridge please
call Customer Service Representatives can be reached toll free at 1 888-523-1930. Get tech support and give them the model and serial numbers. To request to send you a diagram. Nothing on their web site
or email customerservice@westinghouse-home.com
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
I have a Westinghouse L2046NV Monitor and it does not come on. The monitor has gotten worse over time. I have removed the power board and found the six capacitors to the right are all bulging and 3 of them...
You may want to get the capacitor kit, but you need to get the board number used in your monitor version.
Eample of the kit:
http://cgi.ebay.com/Westinghouse-L2046NV-REPAIR-KIT-LCD-Monitor-DAC-19M005-/320608826408
I will not use RadioShack caps, since they are not low ESR type which is required for switching power supply, they will not last if you use generic electrolytic caps.
You should remove one cap at a time so you can see what the value is for each cap.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 18, 2011 | Westinghouse L2046NV Monitor
When Google Chrome will support Selenium IDE as an extension?
There is one trick to use selenium IDE script in google chrome and IE. You can run selenium IDE script from command line to run it on gchrome. Here are the steps for the same. http://software-testing-tutorials-automation.blogspot.in/2013/07/steps-of-running-selenium-ide-test.html
Mar 27, 2010 | Google Chrome
Alternator is pushing 20 volts
1981 used selenium rectifiers which were fairly low amperage. Not likely that overvoltage is the problem, but rather a failed rectifier and not changing to DC voltage (half wave). Get a 50-amp silicon rectifier from Radio Shack and replace it. Better yet, if you now have a headlight law in your state, change to a 50-amp bridge rectifier and gain more charging from the same alternator... be sure to get some help with the conversion from simple rectifier in-line to the battery and a bridge rectifier connecting both battery terminals to both alternator and ground.
Oct 07, 2009 | 1981 Suzuki Gs 550 L
96 people viewed this question
 Grubhead
Grubhead
