Question about Philips 55PP9401 55" Rear Projection Television
PHILIPS REAR PROJECT
TV HAS A BURNING SMELL AND CUTS OFF. IT WILL SOMETIMES PLAY FOR HOURS BEFORE IT CUTS OF
  • Philips Master
  • 8,617 Answers
Your large signal board is getting ready to to go out, most likely due from a defective flyback. Yiu can get a replacement LSB circuit board at the following link.
http://servicemanuals.vstore.ca/
Posted on Jul 14, 2008
I have a philips 42pf55000.switches off ,renove mains ,comes on again ,but no burning smell
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
I have a philips project tv and now I have a
You have defective Convergence IC's along with bias resistors. The average repair cost is around $250.00.
Dec 10, 2009 | Philips 60PP9202 60" Rear Projection...
Burning smell on right side (facing tv)
contact a repairer ur wire inside tv has burnt
Sep 03, 2009 | Philips 30PW8420 TV
TV won't stay powered on, there is a odor and the power led is I believe flashing a 312 code
if the smell is like after a thunderstorm,it is ozone from a high voltage leak in the transformer.if it a burning smell,it could be semiconductors or resistors burning
Jul 08, 2009 | Philips Televison & Video
"pop sound", picture out, burning smell...?
Usually, yes. A bulb that has audibly 'popped' will be apparently bad if you pull it out of the TV (shattered). Other times this is a lamp ballast board.
May 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
No picture
Burning smell can be caused by a blown component, a short, or dust burning inside circuits.
In all cases do not turn TV on untill the TV had been tested and the problem is fixed as you risk to cause further damage to the unit.
Regards.
May 17, 2009 | Mitsubishi VS-5046 50" Rear Projection...
RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Nov 11, 2008 | RCA P60921 60" Rear Projection Television
Magnavox tv
the automatic code is actived.
Nov 09, 2008 | Philips Magnavox 42MF521D/37 Television
Tv does not come on
Those are not good signs. The TV needs repair. I would unplug it and not turn it on again. If the TV is still fairly new say within five years or so, try to find a reputable repair shop. Sometimes the local Better Business Bureau may help or ask around.
Sep 23, 2008 | Philips TP3281C TV
Nero DVD burning Burning problem
Devil is in the details...
1. What O/S are you on?
2. What make and model of PC are you using?
3. What is the burner you are using (make and model)?
4. Most importantly, what kind of files are you burning? (ie, .avi, .mpg, .wmv, etc.). Codec information is very helpful here. Use GSpot to get the codec the vid was encoded it: http://www.headbands.com/gspot/
So it begins!
Feb 28, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Philips 55PP9401 55" Rear Projection Television Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
