Question about AEG Refrigerators
Freezer part is makind a very loud buzzing noise and the freezer is frosting up which is not normal. The temp is -18 for the freezer and 5 for the fridgepart. Also where will the code for the fridge freezer be - we know it is an AEG Santos but which one we don't know, its about 2 years old. thank you
HVACRH20
  • 237 Answers
SOURCE: My fridge makes loud popping noises
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Posted on Dec 23, 2006
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 1462 Answers
SOURCE: I have an electrolux Aeg
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Posted on Oct 08, 2008
localwonder
  • 6784 Answers
SOURCE: ice/frost buildup & loud noise
this is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
Posted on Mar 11, 2009
  • 16 Answers
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Posted on Mar 25, 2009
My haier fridge freezer is making a loud buzzing noise. Any ideas what it is and can it be repaired
Depends what type of buzzing it is?
It may be an alarm telling you something.
It may be a mechanical buzzing from a motor, relay or solenoid.
Check your manual so see if it has alarms.
Google
make model manual
or visit the Haier website
Some do have an over temperature alarm like this one, so check that the freezer door is properly closed and not impeded by frost build up.
Fridge Freezer
Jul 04, 2016 | Haier Refrigerators
Freezer ajar loud noise
Yes Evaporator fan that has ice accumulation in it. Turn off the unit and leave the freezer open for about an hour or two re-start it and hopefully the frost that built up from the freezer being ajar will have thawed and melted away.
good luck to you!
Jun 17, 2010 | Sub-Zero Bottom Freezer Refrigerator
The freezer section of our ge refregerator keeps making a loud buzzing noise and causing our food to frost. I have already lowered the temp.; however, it doesn't seem to help.
This would indicate moisture is getting into the freezer and not getting out.
Run a manual test of the defrost cycle.
Aug 16, 2009 | GE Freezers
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Liebherr CNES 666 freezer - loud fan (?) noise
AbiH, the likelihood of frost inside the fan housing is high. You should manually defrost the unit. Unplug and use a hair dryer to melt as much water as possible. Be aware that hair dryers and water do not mix well! If it happens again, you may have low gas and require a service person.
May 26, 2008 | Freezers
Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
Refrigerators Logo
80 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
bobalix
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
