Question about Dryers
I have a whirlpool estate gas dryer. I am not getting 110 volts to the ignitor. Therefore the ignitor won't glow. any advice? John
    President:
  • 1,314 Answers
Just replace the ignighter it dont get 110 its the way its designed for the safty valve if it dont glow 99percent of the time its bad and even if it does glow it still can be bad as its has to use so many amps for the safty valve to open
Posted on Jul 13, 2008
I have a whirlpool gold gas dryer model#GGQ8858JT1. When I push the start button the dryer starts and spins but the heat does not come o
does the igniter glow? If not check for 110 volts at igniter .
Check for 110 volts at gas valve if no volts check hi limit thermostat , operating thermostat, safety switch on motor,
the coils on the valve & the timer contacts that feed the voltage to the burner.
Mar 02, 2014 | Whirlpool LGV4634JQ Gas Dryer
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
Heating unit on whirlpool dryer not working
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 23, 2011 | Whirlpool Dryers
On a whirlpool clothes dryer I have no heat but I tested for power at both terminals on element and I have 110 volts on both wires going in and element tests proper 10 ohms resistance
You need to have 220-240 volts across the two ends...you can have 110v on each end becuase it feeds through the element...
heatman101
Jan 15, 2011 | Dryers
My Maytag Neptune dryer model mdg5500aww has no heat when running . ignitor never gets red. there's gas to the unit and 110 volts. there really not much lint in there. is the problem the flame sensor?
heatman101
Dec 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
No heat, blower runs, 110 volts to both sides of the element when dryer turned on......
heatman101
Oct 13, 2010 | Whirlpool Electric Dryer Heating Element...
Ignitor does not glow
the flame sensor rarely goes bad
if the ignitor is not glowing
then thats the problem
take an amp reading it shoud be between
2.7 and 3.6 out of that range it will not glow
if your not getting a reading you need to chase your voltage l1 is you most likely culprit
Oct 03, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool lg9521xt gas dryer- no heat or flame. I replaced thermal fuse and coil kit, but didn't solve problem. What's next ? The igniter ?
Remove the bottom panel and start dryer . If you see the red glow , then ignitor is ok . Disconnect the plug (2 or 3 wires ) going to the burner and check for 120 volts . If no red glow , replace the ignitor pt # 279311 . If not 120 volts , then , normally , thermal fuse is bad (white piece with 2 small terminals on blower box ) is bad .
Sep 07, 2009 | Whirlpool Dryers
Gas dryer won't heat up
The ignitor can glow and still be defective.
Take a volt meter and check for power at the gas valve while calling for heat.
If you have voltage, replace the coils again.
No voltage, replace the ignitor and flame sensor.
Mar 08, 2009 | Frigidaire Dryers
New off the showroom floor whirlpool estate dryer, worked fine for a while, now it won't ignite, what do I do?
most likely, either your ignitor is bad, your thermal fuse is bad, or your coil set is bad. if your ignitor glows but the gas does not turn on, then your coil set is bad and the other 2 parts are good. Joe
Dec 02, 2008 | Dryers
Dryers Logo
89 people viewed this question
Top Dryers Experts
