Replacing the pump? on my Maytag HA606
The washer started fine, went through the initial wash cycle, but when it came to the next stage, it stopped. It starts to spin, but when the pump fails to start removing the water, it stops.
What I can't figure out easily is how to open the machine to get at the pump.
On the front of the unit, about 2inches above the floor you will find 2 screws towards the outer edges. Remove the two screws and lift the bottom of the front up and it should snap out at the top. The motor and pump should be visible once the front is removed.
It sounds like you may have a problem with your timer not advancing.
Posted on Jul 22, 2008
I have a Maytag MAH3000AWW Washer. It will start
That is a common issue that is caused by the control board of the machine. You may need to request service to fix this issue. Usually it may be caused by a resistor. Replacing the resistor may make the machine to work for a while but the repair will not last longer. I believe that the machine control board next to be replaced. Something else may be causing the control board to go bad.
Perhaps you were able to feel a burning smell from the washer machine in previous days.
Standing water may be caused by the control board failure because the pump will not operate properly.
Aug 29, 2009 | Maytag Washing Machines
Wont continue to the next cycle
Hi. this washer has a Machine Control Board that is responsible for the initiation of the wash cycles. if this board is damaged in any way, it will produce these symptoms you are experiencing at this time.
I recommend Replacing this Damaged Machine Control asap. if has failed(damaged chip set).
Jun 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I m using maytag pav2200agw after fill the water washer is working fine but during the spin dry cycle water pump does pump out the water and start spin but the tub is not moving its not working propperly...
I WISH I HAD SOME ANSWERS ON THIS ONE, BUT IT SOUNDS LIKE YOUR PUMP MIGHT NEED REPLACING. HOW OLD IS YOUR WASHER? IT WOULD BE CHEAPER TO BUY A NEW WASHER. BUT IF IT IS THE PUMP, THEN YOU CAN BUY A NEW PUMP FROM WHERE YOU BOUGHT YOUR WASHER. GOOD LUCK.
RODNEY
May 12, 2009 | Maytag PAV2300 Top Load Washer
Fisher Paykel will not drain
I had the same problem. After cut the power off for at least 60 seconds and then back on, as the manual suggests, the problem remained. Therefore I started putting the clothes out and bailing the water out. Once the water was down about half way the pump started working. I suspect the sensor was "stuck". I cycled the washer without clothes and it worked fine. Still working after several loads of laundry. The water level sensor will probably need replacing sometime soon.
Dec 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Aug 22, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Machine stops mid-cycle
you need to check your carbon brushes need to be more than 8ml in length now what you also need to do is withthe washer empty fill it up with water on any cycle now put it on the empty cycle make sure it fully emptys the water b checking if the door opens after spin cycle finishes if it doesnt then your pump is either blocked or the fan in the centre of the inside of the pump is weak under pressure which means it needs replacing if none of these then it will be your timer that is faulty which if its a old type washer its not worth replacing the timer m8 sorry these are the only faults that it can be let me know what u find m8
Sep 03, 2007 | Hotpoint First Edition WMA20 Front Load...
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
