Question about Keurig Elite B40 Coffee Maker
No water comes out of the machine
Lots of noise, I just did the initial de-scale thing but no water comes out.
I have tried to brew stuff, but am getting nothing.
  • 74 Answers
Usally load noise in a pump machine is that its getting air in to it.
trie and use a bellow pump and force the water in.
Posted on Jul 14, 2008
Does not brew coffee consistencty, water does not always flow from res tank...even if water flows down from tank the machine will make the heat noise show brew ready and when u push the button it either...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 22, 2010 | Keurig B60 Coffee Maker
Hi! Quite often, when I put a K-Cup in to brew, the Keurig will attempt to brew but just continues to make a humming sound and nothing will come out. I try turning off the power, just opening the lever...
Dec 21, 2010 | Keurig Special Edition B60 Coffee Maker
Sometimes it brews but most of the time it will not. It says ready but still will not brew. Help
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill your mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Dec 21, 2010 | Keurig B70 Coffee Maker
Keurig coffee maker makes loud noise single cup brewer. Make loud noise prior to brewing.
Dec 20, 2010 | Keurig B60 Coffee Maker
THE MACHINE ONLY BREW 1/2 OF THE LIQUID.THE WINDOW READS/BREWING/BUT THE LIQUID STOPS.I GOT TO SHUT THE MACHINE OFF,THEN ON,TO GET ANOTHER 1/2 CUP,BUT SOMETIMES DOES WORK AT ALL.
Dec 19, 2010 | Keurig Platinum B70 Coffee Maker
Have a Gaggia Cyncrony Compact Coffe Machine that doesn't brew!
Has the machine been de-scaled recently? I would run a descaling solution through the machine first to eliminate that.
Jan 15, 2010 | Gaggia Syncrony Compact Coffee...
After descaling my classic, no water is coming out
Try running the descale again it is possible that some of the minerals got loose and blocked the valve in the brew head. If that does not work then you will have to open the machine and unblock the valve or hose that is clogged.
Nov 05, 2009 | Gaggia Classic Espresso Machine
Water pump?
If you could brewer coffee or get hot water out of the steam wand then it could be the one way valve on the bottom of the water tank. If you are running the pump output into a glass then it is probably scaled up in the boiler.
Jan 02, 2009 | Saeco Magic De Luxe Espresso Machine
Keurig Elite B40 Coffee Maker Logo
1,064 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
