Question about RCA F27636BC 27" TV
Picture height adjustment
The picture is too high and I can't find anywhere where the height can be adjusted. It's nowhere on the screen menu and the two knobs in the back are brightness and sharpness.
  • richnedbal Jul 16, 2008
    Oh well. It figures. Thanks for the quick feedback however.
    Genius:
  • RCA Master
  • 1,689 Answers
The screen parameters were factory set by firmware programing during production.
If over time the picture became out of spec, this is due to some components that have changed in characteristics with use and age.
The fix is to have the set properly serviced. The tech will have to troubleshoot the set to find the defective parts and change them.
Jerry G.
Posted on Jul 13, 2008
How do you adjust vertical height on sony bravia tv
Check the aspect ratio set. If it is set to wide, there will be black bars at top and bottom of the screen. Go to its picture setting menu, and adjust the settings. If it do not help you, enter its service mode to adjust the picture height. Although this is a semi-skilled work, if you have patience and concentration, you can do this adjustment. There is no need to open the TV. If you wish to get more details about how to enter service mode, and adjust the data values there, check the site linked here. http://electronicshelponline.blogspot.com/
Dec 04, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tip
Kitchen table, Screen (G2) voltage adjustment, Course 101
Well, those of you who have no idea why a Screen Voltage (technically known as G2) adjustment may interest you, here is a photo of a bad adjustment (too high).
You may also experience smeared colors… this is caused by a low adjustment. To correct this, we need to get the back off of the TV. It would be a good time to unplug it if you have not already done so. Next we locate the FBT (Fly-Back Transformer).
This is a 20” model and it has 2 knobs. Your FBT may vary, as some slim designs and some large tube models may have 3 knobs.
You will need to look closely at the knobs; they will be labeled “Focus” or “Screen”. On units with 3 knobs, there will be 2 focus knobs and 1 screen. For now, we will be working with at the Screen knob only.
With the adjustments identified, we are ready to plug the TV in (including your standard cable connection) and turn it on… BECARFUL!!! For the rest of this adjustment, we will be working inside of an electrically charged TV. We also need to normalize the picture, so go into your TV menu and adjust the Picture and Brightness settings to the middle or center.
If your TV normally displays a black screen when you do not have a signal connected, ex: Video input 1, then this will be the quickest and easiest setup for you to use. However, if you are not so lucky, you may need to bust through your DVD video collection and find a “between scenes” shot that you can pause on to give you as black of a picture as possible. Eliminate as much light in the room as you can (just remember, you still need to see what your doing)… we want a good view of the screen without the interference of ambient lighting.
Once you have your black screen all set, we are now ready to proceed to the adjustment. If you have lines on the screen, see (HIGH)… if you have color smear, see (LOW).
HIGH: If you have some lines in the picture with a washed out appearance, your Screen voltage is too high. You will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
LOW: If you have smeared colors in the picture that seem to trail of the edges, your Screen voltage is too low. You will need to turn the Screen knob on the FBT clockwise. Do this slowly, until you just see some lines zigzagging top to bottom on the screen. Now, you will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
The final set, switch the TV input over to your cable input and check out the picture. Take a good look at some bright scenes and dark scenes. Do they look ok? Adjust the Picture and Brightness in your menu… can you set the picture to your liking? If so, you are all set. If not, double check your work (remember to normalize the Picture and Brightness setting).
If you are unable to adjust the Screen voltage as described above, you may have a High Voltage problem with your TV. This will require a repair and is not covered by this tutorial.
If you are all set and the adjustment is good, we should have a quick look at the focus adjustment. Return the TV to your Black screen setup. Press the TV menu button to give you nice fixed display to focus. Adjust the focus knob(s) until you have the clearest picture. It’s important to balance the center of the picture with the corners of the picture. If the center is too sharp and the edges and corners are blurry, it is not a good adjustment. Do your best, you are the final judge of your work here.
Once you have finished the adjustments and verified the picture with your cable picture, you are ready to close it up and return the TV to normal service. Unplug the TV, replace the back cover… enjoy!
I hope this was helpful. If you benefit from this tutorial, please leave some feedback.
on Mar 21, 2010 | Televison & Video
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
Picture is out of line
One of the following may be misaligned. i) Aspect ratio of your TV may be wrongly selected. i.e. select 4:3 in place of 16:9 or vice versa with your Remote . ii) Picture Width or Height may be wrongly adjusted. With the help of Remote, select MENU go to PICTURE option, reduce height or width which ever is needed.
Have a nice day Rating the solution is highly appreciated.
Mar 07, 2010 | RCA HD52W58 52" TV
How do I adjust the screens vertical height becausee some of the printing is below the frame?
You are in the wrong aspect ratio, either press the ratio button on the remote control (if you have this type), or go into the main menu & select the picture mode, then toggle over to aspect & adjust for a different size of picture. It looks like you are currently in the zoom size
Oct 23, 2009 | LG 37LG30 37 in. LCD HDTV
Model 32 sf36a picture size
most likley they are in the tech menue
you would need the service manul to access the proper proceedure the cause may be caps going bad in the vertical circuit
Aug 29, 2009 | Televison & Video
Picture too big for screen.
go to menu and adjust screen size(picture size)
Jul 29, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Picture problem
It's not an adjustable problem and not all that easy to guess at either. Power supply is a usual suspect and my best suggestion would be to take it to a reliable shop for an estimate.
Bill
Mar 13, 2008 | Sansui DTV3200 32" TV
Televison & Video Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
