Question about Sharp 56DR650 56" Rear Projection HDTV
When tv comes on it says replace lamp and reset timer i replaced the lamp but how do i reset the timer have a 56;; sharp rear projection tv
    Problem Solver:
  • 15 Answers
Unplug your tv and hold the power button for ten seconds then plug it back in if that doesnt work leave it plugged in and then hold the power button for ten seconds.
Posted on Jan 15, 2011
SOURCE:
My jvc 56' flat screen is showing a message in blue to replace lamp but there still is a good picture?
Well, the message is trigger by the passing of time. The TV simply counts the hours the TV has been on, then when the counter hits the designated amount... the message starts to appear. Best thing to do is order a lamp and have it on hand. You can go into the TV menu and reset the lamp timer for now, just to get the message out of sight. When the lamp does fail, change the lamp and reset the timer again. I hope this was of some assistance, best wishes.
Apr 12, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
Upon powering up TV the green light comes on and within a second or two the red light comes on and intermitintly flashes, The tv never comes on?
The lamp or the ballast may be faulty. You'll need to replace the lamp first if this is a DLP. That's the cheapest solution. You can buy a lamp for your TV from discount-merchant.com.
Feb 04, 2010 | Sharp 56DR650 56" Rear Projection HDTV
If I reset the timer before replacing the lamp,will the please REPLACE LAMP warning stop appearing???
Replace Lamp first, then is reset timer come up Go to menu lamp Timer reset.Most of the time TV resets itself after installing New Lamp.
Sep 21, 2009 | Sharp Televison & Video
Replace the lamp, Is there a switch to reset the tV
when you turn the tv on hit menu plus the up volume button at the same time for 3 seconds and that shoud guide you on how to reset timer.
Apr 09, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Warning replace lamp
common problem with this tv. About $130 to replace lamp + service ask ahead for that cost. These lamps are available through the internet. Time left is usually 200-0 hrs after warning
Dec 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Reset lamp timer
Should have been done by whoever replaced the lamp. Must be done from the service port on the rear5 of your tv SEE SERVICE PORT ON BACK PANEL
Dec 14, 2008 | Sharp 56DR650 56" Rear Projection HDTV
56" sharp 56dr650 rear projection tv
Hi - wanted to let you know that I have the same problem and I contacted Sharp (800) 237-4277. They offered me a prorated exchange. Select #1 prompt for Operations and then they will create a case number if you don't already have one and then send you over to the Disbatch Dept. They are picking up my 56" TV and are selling me a LC52"D65U for under $450 current retail value of the new TV $1900. Give them a call and see if they can work out a deal for you too. The whole transaction will take 7 - 10 days. Good Luck!
Dec 10, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Lamp already needs replacing
This TV was made in taiwan for sharp & this is a constant problem Complain enough to sharp & consumer affairs & sharp will repair it
Nov 01, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Have a 56 inch projection tv nothing happens....
Most likely the lamp is defective and see your owners manual for lamp replacement instuctions.
Jan 12, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 56" Rear Projection HDTV Logo
82 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
