Question about GPS
MY TOMTOM WON'T TURN ON. CHARGING LIGHT IS BUT SCREEN WON'T WORK AT ALL NOW.
  • wnor Dec 17, 2008
    I just received the tomtom and plugged it into my computer to charge. The computer recognized it and it turned on but it just sits there with a picture of the tomtom on the screen. Does it have to charge completely before the home page comes on?
    Wes
  • Anonymous Apr 29, 2009
    i got mine for xmas and it stopped wrkng the next day... it wouldnt turn on. now here i am at the end of april. it worked 2 days ago just fine, and today it now for 2 days, i cant get it to come on. ive charged in my car and on my computer for days.
  • 515 Answers
2 Suggested Answers
psycodelek
  • 202 Answers
SOURCE: My tomtom one wont turn on.
there is a reset on that which you will need something small-paper clip works really well-to push in. Pop your memory card out and push in, then hot reset-good luck!
Posted on Nov 17, 2011
Unable to turn it on ,only lighted screen and connection ca be seen
First of all, make sure the battery is fully charged. If you're not sure your car charger is working, try charging it with a USB-cable on your PC/Mac.
Once the battery is charged, RESET your TomTom.
Old TomTom's have a RESET button on the bottom. One model has it's reset button hidden under a cover.
Newer devices don't have a reset button. You reset them by "KEEP PRESSING THE POWER BUTTON A LONG TIME"
Try pressing even more then a minute. Eventually you should hear the TomTom "Drumm Roll" (the starup sound), and your GPS would start normally.
If this doesn't work, Try updating the device firmware using a USB-cable and the right software depending your device. Older devices use TomTom HOME, never ones use TomTom MyDrive.
I wish you a lot of succes!
May 14, 2015 | Tomtom GPS
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Tomtom won't turn on or off. So I can different screens
does the socket in your car stay powered on even when the car is turned off most likely not and you just need to charge your device will itcome on when it is in the cradle for the computer
Dec 27, 2008 | Tomtom ONE GPS Receiver
My tomtom 300's screen will not turn on
On the underside of the unit there is a small hole market RESET.Straighten out a paperclip and push is once.Now switch on. That should work for Ya.
May 04, 2008 | Tomtom GO 300 GPS Receiver
Faulty tomtom go 910
have to send it in to get battery replaced.
Jan 20, 2008 | Tomtom GO 910 GPS Receiver
Lcd screen do not light up
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 14, 2007 | Tomtom GO 700 GPS Receiver
Blank Screen
If it is under warranty return it asap or report the problem...
http://www.tomtom.com/support/index.php?Lid=1
Dec 03, 2007 | Tomtom GO 300 GPS Receiver
GPS Won't Turn On
I suggest any unit under warranty to be returned to its supplier or if they will not help, contact tomtom directly!
Download the latest updates from tomtom.
Will not charge
I have a similar problem and I think I solved it (orr found a way to work around it). It looks like the contacts are not connecting firmly so even though the green light may be on, the charging conneciton is not made. With the tomtom on your home dock from the front page on your tomtom, touch near the lower right of the screen on the satellite strength indicator, this should bring up a screen where it shows (among other things) your batter status at the top right. If it is charging, the word charging will be under the battery strength indicator. Just play with it until you get the word "charging" to appear under the picture of the battery.then HANDS OFF until it is charged. I doubt this will be successful with the car charger since the movement of the car will likely jar the connection loose. Good luck.
Oct 03, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
679 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
