Question about Dell 922 All-In-One InkJet Printer
Dell 924 Carrier jam
'Clear the carrier jam' warning on printer. Carrier stuck on the left side. Whinning sound when turn on, click but does not move to the centre so cannot check if cartridges ok. Nothing appears to be stuck in the printer and no obvious obstruction. Any ideas as to what I can do?
  • 36 Answers
Try and manually move the carrier. If it is stuck, dont forcefully move the carrier.
Posted on Jul 23, 2008
  • gemarcirvin Feb 25, 2011
    my printer dous the same thing and i tryed to manually move it and it still did not work
How to open dell 924 printer case relieve paper jams?
Please follow these steps:
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 01, 2009 | Dell 924 All-in-One InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Paper won't feed and get's stuck
Good luck..
Dec 30, 2008 | Dell 924 All-in-One InkJet Printer
How to clear carrier jam in Dell Photo All in One 944
simply open up your printer and see if there is any residual paper that get stuck, in some case if you can find some small miniature piece of sensor it might cause a erratic sensing that there is a presence of paper while there isnt, try to clear this or clean.
paper jamming indicator means there is some paper in the paper path, unless otherwise ou clear this up you cannnot print.
after you may need to power down or restart your printer once again
cheers
Nov 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell AIO 924 Carrier Jam Problem
To clean the encoder strip, perform the following steps:
  1. Power down the printer and unplug the power.
  2. Lift the cover on the printer.
  3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
  1. Plug in the printer and power it on.
  2. Open the cover to allow the cartridge carriage to center itself.
  3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
Figure 2: The encoder strip to the left of the cartridge carrier.
Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
Dell phto 924 clear the carrier jam
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 10, 2008 | Dell 924 All-in-One InkJet Printer
AIO 924 Carrier Jam
Ink s jammed on left . Will not move to centre
Sep 12, 2008 | Dell 924 All-in-One InkJet Printer
Carrier Jam
The top of my ink cartridge had fallen off and was in the printer... I hadn't seen any paper or anything and was completely stumped, when I picked it up and heard something in there... It was hard to get back on, but now it works!
Jan 08, 2008 | Dell 924 All-in-One InkJet Printer
Carrier jam
This fixed the problem for me : found it on the Dell support website:
Reposition the Encoder Strip
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    new_note.jpg Note: There is a small slot on the back of the ink cartridge carrier, into which the encoder strip fits.
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
Jan 04, 2008 | Dell 924 All-in-One InkJet Printer
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
321 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
