Question about Samsung Digimax S500 Digital Camera
Beeps three times lens is stuck out and won't come on
While taking pictures the batteries died and now with new batteries all the camera does is come on beep three times and goes off. how can we fix this problem?
    Genius:
  • 2,985 Answers
Is the Lens stuck out?
More detail please.
Posted on Jul 14, 2008
4 Suggested Answers
ruteng1
  • 79 Answers
SOURCE: lens is stuck out, camera makes a three beep noise
I'd say the lens gears are stripped or at least out of alignment. Probably due to dropping it on the lens while extended. The camera will have to be sent to the factory or a factory authorized service center. You can also call the customer service folks for help but that will most likely be in vain.
Posted on Jul 13, 2009
SOURCE: Samsung camera power-on problem and beeping
Camera got dropped..had the same problem here, looked after reading this and the smallest part of the telescoping lense was just a little tilted. Gently moved it out and popped it back, works fine now. Another thank you for the tip!
Posted on Dec 24, 2007
VOTIT
  • 2071 Answers
SOURCE: beeps three times lens is stuck out and won't come on
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
If you found these E18 repair instructions useful, consider bookmarking this page or posting your experience in the posting area. If you have any ideas for improving the web site, so it can benefit more people, feel free to share them with us
Posted on Jul 16, 2008
Lens won't close
Lens may jammed or control board is bad. You may need to take it to a dealer or time to buy a new one.
Dec 17, 2017 | General Electric A735 Digital Camera
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
The lens won't open/close and it beeps three times instead
the camera was last on the batteries were either extremely low, or they died and lens could have been kinda off track a little when it happened so it got stuck that way….Put in new batteries and If you lay the camera flat facing up at you and you look down and lens looks a little crooked….Push it slightly in the direction it needs to go to get back on track and when you hear the pop noise it’s fixed. Then when you turn the camera on if it stays on attempt to zoom in and out and the lens will then get back on track…and then TUrn it off and the lens should go back in
Jul 06, 2009 | Samsung Digimax S600 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Instructions
- Bulgarian guide
- Estonian guide
Jul 16, 2008 | Samsung Digimax S500 Digital Camera
Sumsung digimax
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time you will hear a clicking noise which is normal once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Jan 14, 2008 | Samsung Digimax S500 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Oct 10, 2007 | Samsung Digimax S700 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
316 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
