Question about George Foreman GR15 Indoor Grill
Cleaning How do I remove the heating elements to put in the dishwasher and clean? How can i down load an instruction manual? GR20
  • 4 Answers
Yes, I can help... I will make the user manual available to everybody that needs it... it will be in .pdf form. all 16 pages with receipts.. cleaning and how to and what not to do included.
George Forman GR15 indoor grill
link provided
http://fliiby.com/file/56640/eipkgvk3kl.html
Hope you all enjoy the user manual..
Posted on Aug 01, 2008
  • 502 Answers
Get the GR15 manual here
Posted on Feb 19, 2011
Not cleaning the load and leaving soap stains on load
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 27, 2011 | Frigidaire Dishwashers
My dishwasher stopped cleaning my dishes when it was just under 2 years old. I hadn't changed the type of detergent, or how I loaded/ran it. We have since tried different detergents and different wash...
Dishwasher
How to Buy
heatman101
Jan 26, 2011 | Whirlpool GU3600XTV Dishwasher
When we put our dishwasher on it is not cleaning dishes correctly--we have tried to clean it using a dishwasher cleaning agent but this has not worked --do we need to be replacing something??
Dishwasher
How to Buy
heatman101
Dec 06, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Always smells after clean load empty. Water in the reservoir looks dirty. Now see some food deposits on one side of the door base inside machine.
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
A helpful rating and a testimonial would be greatly appreciated if you are satisfied with my solution...
Oct 05, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a Maytag MDB9100A leaving food particles
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
m,.bn
Feb 23, 2010 | Maytag MDB9100A Dishwasher
My dishwasher is not cleaning dishes - it is running through its cycles, but when it is done, there is a heavy residue of soap and hard water and the dishes looks worse than when i put them in.I've changed...
Hello there:
There are 6 areas that could cause this to happen Please follow these simple steps ok
Investigate each of these six areas if your dishwasher is not completely cleaning your dishes:
Water Inlet Valve
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Cycle Selector Switch
Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
Dec 30, 2009 | Kenmore 15899 Built-in Dishwasher
Dishwasher not cleaning load and tablet not disolving I have used a dishwasher cleaner and run it empty on a hot cycle still not working properly
heatman101
c
Aug 13, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
It runs but nothing gets clean maytag dishwasher
With nothing getting clean, the first thing to do is clean the filter and also underneath it. You will need to remove several screws and the lower spray arm to do the cleaning. Watch out for broken glass! Rinse out the filter as best possible.
Look carefully at the impeller to make sure it spins freely and is not damaged. While you are down there, look for any problems (brakes/damage) with the heating element.
Reassemble the filter and spray arm. Test with a load of dishes.
If problems continue, but the spray arms appear to be spinning well, the problem is most likely a failed heating element. Replacing it should make thing work much better.
Please get back to me with what you find. Good Luck!
Apr 01, 2009 | Maytag MDB7100AWB Dishwasher
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Filter/Drain Grate
  • filter
  • . Detergent or Detergent Cup
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Mar 29, 2009 | Dishwashers
    Cleaning
    Only the largest model has removable heating surfaces. You pretty much have to do the best you can with a wet towel after the unit is cool.
    Jan 09, 2008 | George Foreman GR10AWHT Indoor Grill
    George Foreman GR15 Indoor Grill Logo
    383 people viewed this question
    Top George Foreman Kitchen Appliances - Others Experts
    Mike
    Gerry Harvey
    Gerry Harvey
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
