Question about Sharp AFR120FX Air Conditioner
ARF120 WHAT DOES E1 MEAN AND HOW DO IT RESET IT
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
If you have the error code E1 on the LED temperature display. This error code is intended as a reminder for the user to clean the air filter every 720 hours . I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book but on my unit you have to do the following
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
after following this procedure to clear the nefarious E1 indication, you should obtain
another 720 hours of cooling bliss
Posted on Jul 20, 2009
How do i reset e1
Posted on Aug 31, 2008
What does E1 mean in tadiran 250 R, it works then stops and screen shows E1 when it operates as a heater
h Air Conditioners
Nov 24, 2012 | Heating & Cooling
Error code E1
this type of code normally mean Control Board Problem. You must call to the profesional repairmain. However you can do the following :
Enter the Service Test Mode as follows:
1. Open door.
2. Press DELETE.
3. Press pads 1, 3, 5, 7.
4. Close door.
5. Press DELETE within 15 seconds (Pressing RESET at any time will cancel the Service Test)
Sep 16, 2012 | Microwave Ovens
What does error code #e1 mean on Canon CLBP 460 PS mean?
Meaning of error code E1
The motor sensor or sensors, the DC controller on the main board DC controller.
I can not give solution to your problem, because possibility of damage main board.
I suggest you contact Canon Customer Support (e-mail, telephone, or repair contacts).
Nov 16, 2011 | Canon CLBP 460 PS Laser Printer
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
What is the error code mean e1 d3 in intel 845 gly motherboard..
Please find below the link for the product spec of this motherboard
http://downloadmirror.intel.com/15210/eng/D845GVSR_TechProdSpec.pdf
D3 refers to "Do necessary chipset initialization, start memory refresh, and do memory sizing."
E1 is not a known error code for this motherboard according to the manufacturer, please reset your bios settings to factory defaults.
refer to page 100 of the same document for the procedure. (after getting into your BIOS settings page)
Nov 30, 2010 | Intel D845GVSR Motherboard
What does E1 flashing on display mean? The air conditioner comes on for 10 mins. and then flashes E1 in the display. I have cleaned filter b lown out grill and still no results.
if its a sharp ac ... it will need to be reset..
1) hold down the on/off button keep it held down and plug in the ac ..you should hear a beep...
2) hold down the mode button keep it held down and plug in the ac ..you should hear a beep...
one of two ways will reset the e1 error hope it helps..
Sep 19, 2009 | Heating & Cooling
Error E1 mean?
An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced.
http://www.appliance411.com/data.php?rc=548392
pls rate my suggestion...
Jun 26, 2009 | Whirlpool Washing Machines
My electric just recently went out and when my stove came back on it's blinking F1 and E1. I can use my burners but not my oven. Can it be reset?
E1 and F1 mean the electronic control board has failed. Unfortunately other than resetting the breaker replacing the part is the only solution
Dec 23, 2008 | Kitchen Ranges
Sharp AFR120FX Air Conditioner Logo
312 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
