Question about Samsung HCM4215W 42" Rear Projection Television
HCM4215W convergence issue
I changed the sub PCB red and the main convergence board last fall and all has been GREAT ever since.
Now if i try to enter Mute+182 the menu does not show up and my convergence is all screwed up again. Also the power DOWN tones are gone , but stil get the 6 or so ascending power up tones.
Do you think i need yet another main convergence board?
if so i may still be under warranty.
any help would be welcome, and you can also email me directly at
thanks alot in advance.
  • 132 Answers
Mute 183 power.
You may have done alignment previously in service mode and not initialized or saved correctly. add/erase saves
The test for convergence ICs working is if the V and H can be adjusted for all colors in different picture quadrants. The adjustment may be so far off that it looks broken.
There may be low ohm resistors that have increased in value. Some Samsung chassis use low ohm resistors that have built in Zener diodes for stabilizing the voltage drop across the resistor. Replacing with ordinary resistors (as the schematic shows) may cause poor convergence that can be adjusted after warming up, but always varies noticeably when going from cold to hot.
Using the correct part number from Samsung will ensure that the right part is in place.
When 1 or 2 ICs fail with no resistor damage, only small or no adjustment is necessary (if the replacement ICs are well made and imitate the original). When resistors burn and are replaced, adjustment is required more often than not.
Call someone that has aligned and repaired numerous Samsung RPTVs and your problems will be over.
There is a list of repair techs on the Home Page. Projection Televisions
If you are in Calgary, call me.
Posted on Aug 24, 2008
Samsung HCM4215w has wavy red lines and bowtie effect
Are you saying that after installing a new convergence board, you still have the same issue? If that's the case, another new board isn't going to resolve this. Also, you can't do a factory reset. Doing that would lose all the convergence and geometry data in the TV and would require a qualified technician hours of work to restore the settings. If you've installed a new board and have the same problem, suspect a problem in the TV's power supply. All convergence circuits require 2 voltages to operate. There will be a postive and a negative voltage of the same value. If you're missing either of these voltages, your convergence will never work properly.
Feb 17, 2009 | Samsung HCM4215W 42" Rear Projection...
Red Convergence Issue( Samsung HCM4215W)
Bad chips or faulty soldering.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Dec 23, 2008 | Samsung HCM4215W 42" Rear Projection...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 29, 2017 | Samsung HCM4215W 42" Rear Projection...
Samsung 42" rear projection HD tv issue
1 they are either rebuilt or a defective returned to stock accidentaly
2 yes securly attaching it helps the heatsinks keep even cooler. no you don't need heatsink grease.
3 if the tolernace is very far out of wack then it woun't take long befor they blow. once you have instaled the new board turn on the set enter mute,1,8,3 then perfect focus on the remote let it do it's thing then shut off the tv and resart the tv and press perfect focus again.
Mar 05, 2008 | Samsung HCM4215W 42" Rear Projection...
pico fuses are those small on board fuses, usually soldered into place, that protect important parts of the board.
Feb 26, 2008 | Samsung HCM4215W 42" Rear Projection...
No Picture, Not Convergence Board Problem
PVAT! Give a real close look at the signal pcb for evidence of coolant leak.That will pull down power circuits, giving all kinds of strange symptoms.
Oct 07, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung hcm4215w Convergence board problem
Use PANASONIC STK's.They are expensive,but they hold up!Safe,durable repairs require OEM or BETTER quality replacement parts.
Sep 27, 2007 | Samsung HCM4215W 42" Rear Projection...
HCL4715W Rear projection CRT problem
your screen and focus controls need adjustment to acheive a good grey scale picture the adjustment are not on the crt neck boards.(focus block)
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
56 projection t.v. color problems
If you mean they are separated like a 3-D effect, then you have the typical bad convergence IC problem. There are two IC's mounted on a large metal heatsink, they will have STK392-###, the ### being differant models of TV sets. these are soldered into place and are no usually replaced by the user, unless you have solid state repair experience, knowe how to solder, have a schematic on the set, and know the High voltage safty factors of projection TV serviceing. If you have no experience, please play it safe, and get someone who is trained to service TV sets. Good Luck Please do not forget to rate this thread.
Dec 08, 2006 | RCA P52926 52" Rear Projection Television
Samsung HCM4215W 42" Rear Projection Television Logo
102 people viewed this question
Jerry Greenberg
Jerry Greenberg
