Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile Side by Side Refrigerator
I have a leak from beneath onto the floor on the left side (facing the unit), it's not a constant leak, however it's becoming more frequent. It causes a poodle on floor approximately every two days. We have a ice maker in opreation, it seems to work fine, the freezer and the frigeration sections appears to working properly. Any suggestions what I should look for?
  • botete Jul 17, 2008
    I have the same problem, only my in now leaking every day and the puddle sometimes is larger than the previous day.
  • Anonymous Aug 31, 2008
    We recently purchased a home that came with this refrigerator and are having the same problem. We'll try your suggested fix and let you know how it works!
  • 74 Answers
This is probably the ice maker water feed becoming detached from the back of the appliance. This is a fault of a leaky watervalve or low pressure allowing water to drip into the feed pipe where it freezes building up until the pipe blocks where water pressure causes it to bacome detached. Change the water valve and refit the pipe ensure there are no airleaks into the freezer.
Posted on Aug 28, 2008
Water drip on to floor from rt.rear. profile side by side
Tube may be a ice maker supply line. You can replace it at any home depote
Apr 29, 2014 | GE Profile : PSCS5RGXSS Refrigerator
GE Profile side by side TPH21PR refrigerator leaks water on the floor at left front corner weekly but not daily. It there a fix or should we purchase a new refrigerator.
it sound like the drain pan and the drain line need cleaned or maybe the drain tube got knocked out of the pan, take a light and look and see what you find down there and let me know.
Feb 21, 2011 | GE Profile PSW26P Stainless Steel Side by...
I have an 8 year old GE Profile Side by Side TPX24PB Refrig that is leaking water in the freezer, but not the refrigerator. There is a slab of ice on the freezer floor, eventually water runs onto the...
The drain is clogged. Remove the bottom bin out of the freezer. Once done you should see a trough at the back. This trough will be filled with ice, remvoe the ice. Then you have to clear the drain. The best way I know of to do this is to force hot water down the drain with a turkey baser untill water flows freely. Then mix baken soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 24, 2010 | GE Profile TPX24PBDCC Side by Side...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Water leak under GE Profile refridgerator when using door water
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | GE Profile PCF25PGW Side by Side...
Water from GE Profile Refrig/freezer drips down back inside freezer wall and fills up, bypasses drain and fills up and leaks into floor.
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Jul 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Leaky Refrigerator
remove the whole back cover at the bottom and check all the nylon lines. they get britle and crack from the heat that the compresor and condesor make. chack that and get back to me. I may be able to send a parts break down / explosion if I can get the model number.
Cheers,
Todd
Oct 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leak
There is a problem with the condesation drain being plugged in the bottom of the unit. The water is supposed to drain onto a "condensation pan" under the unit where it typically evaporates without causing problems.
I believe that the solution was to pour bleech in the drain...
Aug 01, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking on floor from under Mod#TPH21PRS;TPH21PBS
I you dont have any water hooked up for the ice maker or for water at the door, about the only thing left is your freezer drain. Look in the back under the freeser side and look for a drain... see where it drains.. over flowing? anyway water could get out from where in drains to?
Aug 21, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
151 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
