Question about Whirlpool Duet GHW9150P Front Load Washer
Washer leaks on on the floor when using a large load setting.
  • 4,889 Answers
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Posted on Jul 17, 2008
Water seems to be leaking from the bottom of my Maytag washing machine. Machine set for a large load. Water stopped, I added the detergent and then the soiled laundry. I went to get other laundry I had...
unplug washer. pull washer to you, have someone tilt the washer back and get a flash light and look for water spots on water pump,your drain hose,could be aclanp or just a hose we hope.
Sep 17, 2011 | Washing Machines
Afront load washer leaks around soap dispenser
we had this problem with our washer (samsung wf316bac) for a while. 2 service calls did nothing to fix it. Washer is level, use correct soap and amount, etc. etc. I had to turn down the hot and cold water faucets to fix the problem. It worked. I think there is a siphon problem with the soap dispenser design... On a very large load we now get the 'nf' (no flow) message and have to start the washer again. Beats water on the floor... Samsung denies having any problem but you will find this all over the interent. hope this helps...
Jan 04, 2011 | Samsung Washing Machines
Amana washer model# nav4800aww leaks water on the floor while washing large loads. Now it does it on all loads.
firstly remove rear cover and check during running if any hose is leak?
or-
water seal inside drum is leak for this drum has to be open. mostly bearing are damager due to water entering bearings. so bearing are needs replacement.
Nov 05, 2009 | Amana Washing Machines
Leaks water on floor and spin cycle very loud
if it sounds like a boeing jet, you will need a new seal & bearing kit. This is something a technician would have to do. many "special" spanner wrenches and spring tools required
Feb 23, 2009 | Maytag PAV2300 Top Load Washer
Washer leaks now when doing large loads.
pop the front panel you can do this with a putty knife. where the top is 2 inches down you will see a creas use a flash light you will see the 2 clips push in on the clips and pull out you will be able to access where the tub is to see where the leak is comeing from
Jan 04, 2009 | GE WBXR3100B Top Load Washer
Leaking on the floor on "small load" setting only
I have been selling and been doing factory authorized service on GE for nearly 30 years. I have sold many of this model. It's hard to imaging that a machine would leak water on small loads but not larger loads. In a case such as this, a servicer must remember to test the machine exactly as the home owner is using it. I would take pull the machine away from the wall and adjacent cabinets and dryer if hoses permit, (so that I could rule out water coming from somewhere other that the washer) remove the front panel, and have the home owner run the exact cycle with the exact settings and the same clothes load and soap used when the machine leaked. I suspect that some water is splashing over the wash tub. If you use a gentle cycle or a larger load you get less splashing. Even having a few more cloths items in the machine would reduce splashing. You might not expect a solution, but you do deserve an explanation. Some times the solution is strange, for example: I had a customer who said the washer leaked a lot of water onto the floor the first time it was used in the day, but worked great the rest of the day. I came out early the next day and tested the machine, and it did exactly that. What happened was the builder added on this new laundry room and the drain pipe went through the floor before the plumber added the trap. The builder then insulated the area but put the insulation on the room side of the trap, allowing cold air to freeze and plug the drain. After warm water pumped into the drain and most of the water overflowed the top of the pipe onto the floor, the rest of the water melted the ice in the trap and the machine worked fine until the next day after the water had a chance to form a later of ice in the trap again. The fix was simply to move the insulation to the other side of the trap. (OK, here in Minnesota we run into weird things like that, but my point is to test the machine exactly as it is used to find where the problem lies) I'd like you to post a comment when you find your solution.
Nov 02, 2008 | GE WDSR2080D Top Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
290 people viewed this question
Dan Webster
Dan Webster
Sal De
