Question about Kirby Ultimate G Bagged Upright Vacuum
Replacing vacume belt
I need step by step instructions on how to change my belt it;s off but I need to know how to put it back on...Thanks
  • dutch_supers Jul 15, 2008
    Thank you so much... It's up and running now
    President:
  • 1,673 Answers
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Posted on Jul 13, 2008
How do i change the belt on the dirt devil vacume cleaner
Hi there! Below are steps to replacing the belt on your vacuum. I have also included a link to the instruction manual which has illustrations if needed.
1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the four (4) screws. Arrows show location of screws.
2. Lift nozzle guard off.
3. Slide belt off motor shaft.
4. Lift and remove brushroll. Dispose of old belt.
5. Place new belt in area of brushroll without bristles.
6. Slide belt onto motorshaft.
7. With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
8. Reattach nozzle guard.
9. Secure by aligning the three (3) tabs in the base slots. Be sure to replace all four (4) screws.
http://bit.ly/1s8GQSX
Hope this helps!
Jul 27, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Belt
Flip the vacume upside down take picture with camera phone start taking it apart slowly take pictures as you go you will see the belt put it back with the help of the pictures
Jun 25, 2012 | Vacuums
Cleaning rollers and belt come off on one side, cannot figure out how to put back.
For wonderful step-by-step instructions on how to replace the rollers and belt, please refer to pages 17-19 of the user manual located here:
http://www.sylvane.com/images/prodphoto/bi1129/CleanShot_User_Manual.pdf
Let me know if you need clarification, and I'll assist. I hope this helps. Please rate this solution.
Thanks!
~PCF
Mar 07, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replacing the belt
remove the two screws from the top of the vacume instead of from the bottom and it will be right inside there.! changeing the vacume belt after that is all very simpl and self expl.
Mar 12, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
I have no idea how to put the belt back on
Jul 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Brush
Put the belt over the brush roll, set it in the middle, put the brush roll into the head and put on the bottom plate. Turn the big knob on the front of the nozzle to catch the belt, turn it until it locks into place. Then put the nozzole onto the front of the vac, then turn the knob all of the way the other direction, it will put it on the motor pulley.
Jun 01, 2008 | Kirby G4 Bagged Upright Vacuum
How do i put a belt on my kirby vaccum
here is a link to a site with step by step instructions for replacing a belt on any G series kirby...it also works for the new model.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps! :)
Feb 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 28, 2007 | Hoover 5416-900 WindTunnel Bagged Upright...
Kirby Ultimate G Bagged Upright Vacuum Logo
61 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
