Setting up a router
I've been trying to set up a westell 6100 to a dlink wbr 1310 wireless router. I set up the modem as a bridge, disabled the dhcp and connected everything. I also set the wireless router for a PPPoe connection and it's still not working. Any help would be appreciated!
  • defender710 Jul 16, 2008
    Tried, didn't work.
  • 3 Answers
Set modem as router, enable dhcp, and set router as dynamic
Posted on Jul 15, 2008
I HAVE A DLINK WBR-1310 ROUTER WHERE DOES THE BLUW
Hi!
You can use any UTP cables. Here is how the connection would look like:
DSL -> DLINK WAN PORT
DLINK PORT 1(or any other ports) <---> COMPUTER
If the router is set to give out IP addresses automatically(DHCP), you should be able to connect flawlessly.
Oct 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Can't connect my wrt56gs to my westell 6100 modem, could you please help?
You are using westell modem that means your internet service provider must be DSL.You will need to make sure that your computer is able to go online when connected to the modem. that will decide the type of ISP connection.
Click Here for more info on how to set up the router.
Oct 18, 2009 | Linksys Wireless-G WRT54G Router
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Bridge my router
Since you have two routers, both of them are trying to assing DHCP address to the network, so all you need to do is just disable DHCP on the netgear router, there fore the westell will assing the address.
Are you just trying to use the netgear for wireless?
Jan 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Westell 6100, to smart for job!
you have to activate DHCP in order to make the westell a modem "dummy" (it will just act as a bridge to the internet from your Linksys.
on the modem, go to a setting that is similar to "Public Routed Subinterface". dont choose anything that says "proxy" or "NAT".
find out the Linksys's IP adress by looking at the devices or computers list on the Modem's home page.
Now, put that IP adress on the setting "Public Routed Subinterface" (or similar). If it has a "Subnet Mask" option, type in "255.255.255.0". Also, If it has a "open firewall" or "bypass firewall" option, enable it.
If it does not have a firewall option, disable the firewall on the MODEM, not the linksys. This is also called DMZPlus mode.
If the above does not work, go here on the entire instrucitons for setting up the linksys with your modem.
Aug 20, 2008 | Westell Wirespeed LiteLine 6100...
I can't get DMZ on Westell F90-610015 to work.
NEED TO FIND THE DRIVER FOR WESTELL MODEL 6100F cAN YOU HELP?
Aug 11, 2008 | Westell Wirespeed LiteLine 6100...
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
May 21, 2008 | Westell Wirespeed LiteLine 6100...
D-Link Router & Actiontec Modem
connect the Dlink router to the modem ActionTech->( wan port )Dlink. Login to the Router web-interface and go to STATUS & check the WAN IP address which would be modem ip address. if there is an ip address, do ping test on your computer to that ip address and see you are getting successful ping results. If so, the ping yahoo.com and see there is an successful ping for yahoo.
- If there is No WAN IP in STATUS Page, Connect the computer directly to the modem and let me know the ip address you are getting. Can I know your ISP name please?
Oct 24, 2007 | Computers & Internet
Computers & Internet Logo
471 people viewed this question
David Payne
David Payne
