On a dell optiplex gx150 is there a place where to find the header pins (front panel) spec's of these pins?
  • 50 Answers
Hd not recognized in dell optiplex gx150
Quick look at info form DEll gx150 Dell Search All Dell com shows me your motherboard is useing 40 pin ATA interface. So you need to be sure the drive is set to "master" or "Slave" and plugged into the ribbon for the interface in correct order. Master is located at the end of cable, slave is in the middle of the ribbon. Drives also have jumping pins that need to be set for Master and slave. There is a difference from one manufacturer to another. But the info is on the drive itself most time. Look close at the label on the drive for the settings for slave mode.
May 26, 2014 | Dell OptiPlex GX150 - Celeron...
Dell OptiPlex GX150 no display no sound with yellow led
Hi, just pull out your memory card and clean it with an eraser. And insert it tightly again and don't forget to clean also the memory bank.
Hope it will help you.
Mar 27, 2012 | Dell OptiPlex GX150 SF PC Desktop
How to bypass power button on dell gx150
See http://support.dell.com/support/edocs/systems/opgx150/en/ug/about.htm#inside for a view of the internal connections for the Dell GX150 motherboard and front panel connector.
You would need to try to identify which wires on the front connector pin block are used for the power switch then use a meter to check whether the switch makes a temporary or permanent connection between those pins to know whether you could just jumper them or not.
Dec 22, 2011 | Computers & Internet
I disabled the video on my dell optiplex gx150 to try to run a different video card and now I've got nothing. How do you turn the video back on when you can't see the screen?
I would open up the case and take the cmos battery out. In addition, look at the motherboard to see if there is a set of jumpers near the battery that say something like clr or clrcmos (I can't tell by looking at the diagram on Dell's site if there is one). If you find 3 pins labeled like that, switch the jumper to the alternate position and then back again after about 15 seconds.
Now replace the battery.
Start the system and see if it works.
Oct 22, 2009 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
34 pin FRONT PANEL insert locations.
http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
This link should open an html document from Dell, providing you with all the information you seek.
good luck
tony
May 20, 2009 | Dell OptiPlex GX270 PC Desktop
Can a OPTIPLEX GX150 be upgraded to a p4 it was a cheap xmas present and just would like to know
No. Even if it could you could only use 1ghz of a 3 to 4 ghz processor. You will need to buy a new motherboard in order to do that. Here is the specs. let me know if it isn't the right computer.
http://www.bizrate.com/desktopcomputers/dell-optiplex-gx150-1-ghz-pentium-iii-desktop--pid306165798/
Dec 30, 2008 | HP Pavilion 8650C PC Desktop
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
